Geeetech Thunder 3D printer
Revision as of 06:36, 13 September 2022 by Admin (talk | contribs) (FAQ)
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
Cura Configuration File
Thunder Cura 4.13 Configuration
User Mode Introduction
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
How to Acquire Support
I. Create a ticket in Help & Support Column in your account, technical staff will help you
Steps:
A. Open our website: www.geeetech.com,then Log in or Register a new account
B. Click your account and select“Help&Support”
D. Infill the ticket detail,including description and some pictures/video links of the issue
How to Buy
Click to Purchase
