Geeetech Thunder 3D printer
Revision as of 05:39, 13 September 2022 by Admin (talk | contribs) (How to Buy)
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
Cura Configuration File
Thunder Cura 4.13 Configuration
User Mode Introduction
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
No, Thunder is designed to achieve high-speed printing with ordinary PLA filaments, so Thunder can achieve high-speed printing with ordinary PLA filaments..
How to Buy
Click to Purchase
