Geeetech Thunder 3D printer
THUNDER is a high speed FDM 3D printer with a printing speed of up to 300mm/s. After two years of research and development and testing by GEEETECH engineers, it has achieved high speed printing while ensuring excellent printing quality. It is an excellent 3D printer that can save a lot of precious time for 3D printing enthusiasts.
Product Features
•Technology: FDM
•Dual Z-axis
•Multi printing modes: THUNDER inserted 4 printing modes for different speed level printing, meanwhile, it has a User Mode for users to customize printing parameters
•Break-resuming capability
•Printing lighting: THUNDER designed a white LED light on the hotend, convenient for checking the nozzle and model condition
Product Specifications
•CPU: ARM Cortex-M4 Core, 168MHz
•Printing Speed: ≤300mm/s
•Maximum Acceleration: x=5000mm/s², y=4000mm/s²
•Motion Controller CPU: ARM Cortex-M3 Core, 72MHz
•Nozzle Max Temperature: 250℃
•Hotbed Max Temperature: 110℃
•Nozzle Diameter(Optional): 0.2mm, 0.6mm, 0.8mm
•Filament Diameter: 1.75mm
•Power Input: AC 115/230V, 50/60Hz
•Power Supply: 350W
•Net Weight: 10.7kg
•Packing Weight: 13.4kg
Notice
Cura Configuration File
The THUNDER printing speed can reach 300mm/s. In order to ensure the printing quality even in high speed, the correct setting of slicing parameters is essential. We recommend the Cura slicing software and provide the THUNDER configuration file for Cura slicing software on this page.
We offered 2 configuration files for THUNDER, see below about importing file to Cura software.
User Mode Introduction
In order to enable users to better use and adjust THUNDER, we have opened the parameters of the core algorithm of THUNDER firmware. Users can adjust the parameters of THUNDER according to the usage scenarios and requirements to obtain better print quality. It should be noted that THUNDER may also get worse print quality due to the adjusting of some parameters.
User mode requires using the Smartto Kits tool and modifying parameters via USB. Users can also export and share their configuration parameters with other THUNDER users, or import parameters from other users into THUNDER.
5.Click the "Disconnected" button in the upper right corner. The Setting interface is displayed in left side. Select the serial port for THUNDER, set the serial port baud rate to 115200, and click "Connect" to Connect THUNDER.
Import: Import THUNDER configuration parameters
Export: Exports the THUNDER configuration parameters
Get Status: Reads the current parameters of THUNDER
Use Default: Use the factory Default parameter of THUNDER (print mode)
Save: The saved parameter is valid only for this time. The parameter becomes invalid after restart THUNDER
Apply: Write the modified parameters to the THUNDER Flash memory
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
THUNDER does not support TF card upgrading firmware directly. You need to use Smartto Kits to upgrade the firmware through the USB cable. The steps are as follows:
4.Click the "Disconnected" button in the upper right corner. The Setting sidebar is displayed in left side. Select the serial port for THUNDER, set the serial port baud rate to 115200, and click "Connect" to Connect THUNDER.
UI Upgrading
A TF card or USB flash drive is required to upgrade the UI of THUNDER. See following steps:
Step 2: Insert the TF card or USB drive into THUNDER, and then power on THUNDER. At this time, you will see that the display screen is updating the UI. This process takes a long time, please wait patiently.
In addition to the 0.4mm diameter, THUNDER also supports 0.2mm, 0.6mm and 0.8mm diameter nozzles. For these diameter nozzles that is not commonly used, there are some parameters that need to be set and adjusted when using the slicing software. Based on experience and validation, we offer 0.2mm, 0.6mm, 0.8mm diameter nozzle slice parameters for THUNDER for user reference, see the table below (or download the Excel table).
THUNDER's X/Y axis motors are all closed-loop controlled, and the closed-loop control sensors on the motors have been calibrated before delivery. Do not remove the closed-loop control sensor if the X-axis and Y-axis are not abnormal. Otherwise it will cause the calibration parameters of the closed-loop control sensor on the X-axis and Y-axis to be offset, resulting in the X-axis or Y-axis stuttering or abnormal jitter during the THUNDER printing process.
On the screen menu of THUNDER, we provide the X-axis and Y-axis closed-loop control sensor calibration function. The specific path is "Operate" → "Motion". In the "Motion" menu, you can see two buttons "X Encoder Cal" and "Y Encoder Cal". They are X-axis and Y-axis closed-loop control sensor calibration buttons respectively. The specific calibration methods are as follows:
Nozzle discharge abnormality
First layer abnormal
Layer shift
