Iduino Yun Cloud
OverView
  • Built-in web server
AVR Arduino microcontroller
  • Microcontroller ATmega32U4
  • Operating Voltage 5V
  • Input Voltage 5
  • Digital I/O Pins 20
  • PWM Channels 7
  • Analog Input Pins 12
  • SRAM 2.5 KB
  • EEPROM 1 KB
  • Clock Speed 16 MHz
Linux Microprocessor
  • Processor Atheros AR9331
  • Architecture MIPS @400MHz
  • Operating Voltage 3.3V
  • WiFi IEEE 802.11b/g/n
  • USB Type-A 2.0 Host
  • Card Reader Micro-SD only
  • RAM 64 MB DDR2
  • Flash Memory 16 MB
WiFi Specification
  • Connector: I-PEX connector.
Quick Start of Iduino Yun
Connect to Iduino Yun
Choose Yun profile
Use Yun cloud with Arduino board
Connect to Arduino Board
Connect to Leonardo
Connect to Arduino Uno
Connect to Arduino Mega2560
Detect Iduino_Yun_Shield
Upload Sketch
Reference
