Delta Rostock mini G2
Main features:
Specifications:
The Layer Thickness: 0.1mm
Layer Resolution: 0.1mm
Print Speed: 60 to 120 mm/sec
Print Plate Size: 210 x 3mm
XYZ Bearings: carbon steel
Output:DC12V/0-15A
No. of Extruders: 1
Electronics: GT2560
Machine weight: 7.5kg
Shipping box dimensions:
Shipping box weight:
building instruction
install drivers and software
Install the drivers
here.
Macbook (OS X) Manual Install
Click "Continue" in Read me.
Click "Continue" in License.
How to set up
Printer setting
Home X: 0
Home Y: 0
Home Z: Max
Printer Radius: 100mm
Printable height: 210mm
Start G29 Command
Printer preparing
3)send G 0 X-43.3 Y-25 Z2, record the distance;e.g. it is 2.2mm in my case.
  • If the nozzle touches the center point but not the around points, you should reduce the DELTA_RADIUS
  • If the nozzle touches the around points but not the center point, you should increase the DELTA_RADIUS
Modify the firmware of Delta
We have pre-loaded the firmware to GT2560 before shipping, but as this is a DIY printer, there may be some subtle difference between each printer, so you need to modify the firmware to fit your exact printer for better printing effect.
1. Download the firmware here. And unzip the zip/rar file.
2. Open Arduino IDE. ( If you do not have Arduino IDE, you can download here.)
3. Drag all the files into Arduino IDE.
4. Click Configuration.h and find out Delta Settings
  1. define DELTA and modify the values as below.
