Delta Rostock mini G2 dual extruder
Revision as of 02:52, 20 May 2015 by Admin (talk | contribs) (Created page with "[[File:dual extruder.jpg]|500px|] =Copyright Declaration= The copyright of this manual belongs to the Shenzhen GETECH CO., LTD. (hereinafter referred to as the "Geeetech"), ...")
The copyright of this manual belongs to the Shenzhen GETECH CO., LTD. (hereinafter referred to as the "Geeetech"), and all rights reserved. No part of this specification should be reproduced or extracted in any forms or means without the prior written consent of Geeetech by any company and individuals.
Technical Support
If you are interested in the technology of 3 D printing, flight control and U-home, welcome to Geeetech, we have series of made-up products, main boards, modules and a variety of peripherals for you. Or if you are looking for relevant information or technical support, please login our Forum where you can find anything you want about open source. To know more about our new products, please visit www.geeetech.com, we will serve you wholeheartedly.
SAFTY INSTRUCTIONS
Building the printer will require a certain amount of physical dexterity, common sense and a thorough understanding of what you are doing. We have provided detailed instructions to help you assemble it easily, please download at geeetech.com.
Introduction:
Delta Rostock mini G2s succeeds the advantages of the previous version on the respect of steady structure, small physical footprint, simple but really rigid frame, high positioning accuracy, flexible effectors, and very similar specification, and we add some innovative design, such as dual extruders, the brand new control system, the use of Rod-End joint Bearings and metal diagonal rods, on-built LCD control panel and support for multiple filament type.
Package list:
This list includes all the parts required to assemble your Delta Rostock mini G2s 3D Printer. After you received your package, please check if all the parts listed are included. Also make sure all the components are in good condition and not damaged during shipping. If anything is missing please contact with our customer service straight away, provide us the NO. , Name, and Qty.
