Delta Rostock mini G2 Building Instruction
Preparation
Chapter1 Base Assembly
Motor end assembly
Stepper motor
53
3
Pulley
33
3
Motor holder
A3
3
Motor holder support
A4
6
Square nut
14
6
M3 X 12 Screw
18
12
M3 X 16 Screw
19
6
M3 washer
5
18
base plate
A2
1
Square nut
14
9
M3 X 16 Screw
19
9
M3 washer
5
9
Mount the LCD panel
LCD frame LCD frame
A8
1
LCD support
A9
2
LCD2004
54
1
Square nut
14
4
M3 X 16 Screw
19
4
M3 X 12 Screw
18
4
Spacer
34
4
M3 washer
5
8
Knob
55
1
Mount the fan
