GT2560
1 Introduction
GT2560 is a compact board that is integrated with the mighty function of the Arduino Mega2560+Ultimaker. The GT2560 can not only
take full place the Arduino Mega2560+Ultimaker on respect of both software and hardware, but has more premium features: the
streamlined interfaces effectively avoid the unnecessary troubles, well-regulated compaction of components highly integrated saves
more space and easier to be mounted on most applications. 5 stepper motors, swappable driving modules, mighty ATmega2560 processor with 256k memory, 16MHz operating frequency, high-
performance USB serial converter FT232RQ, all these make the GT2560 an ideal option for a 3D printer control board. What’s more,
GT2560 can run over 12V and output 90W to a MOSFET, which gives higher torque and higher rotation rate.
Features: 1.Integrated with the mighty function of the Arduino Mega2560+Ultimaker, The GT2560 can not only take full place the Arduino
Mega2560+Ultimaker on respect of both software and hardware, but also features compact size, more convenient connection, and more
stable. 2. Adopt ATmega2560 as the main control chip, coupled with the high-performance USB serial converter FT232RQ. 3. The power pack: operating voltage is 12V-24V; double power supply design feeds for heatbed and logical part separately. The
current is 12A for heatbed and 5A for other parts. The cooling fan can support 12V 4. The main circuit adopts SMD fuse tube, the diode added to the power port can provide reverse protection to the whole circuit, in
addition, the 5V USB is USB port protected with 500mA Recoverable fuse. 5. 3 12v fan output and one PWM output for LED or other lighting equipment. 6. 3 55Amp MOSFET (with LED indicator, the actual output is restricted by the PCB board and the connector), all 3 MOSFET are
equipped with heat sink to ensure sufficient heat dissipation and stable operation. 7. Support 5 A4988 stepper drivers (3 for X/Y/Z axis, and 2 for extruders); the subdivision of stepper motor can be setup by dial
switch, eliminating jumper caps, easier to operate. 8. 3 temperature sensor input (100k thermistor is recommended) 9. Extended LCD and SD card interface support both LCD2004 and LCD 12864, with which you can print without your PC. 10. The firmware is the prevalent Marlin, which is known for stability, usability, and high-performance.
1.1 Overview and Hardware Resources
1-1(front and back images) Hardware resources
12V 12A and 12V 5A power supply 1 power port for heatbed and 2 for extruder
3 input for12V cooling fan
1 PWM output
weight: 80 g
1.2 Software Resources
Compiling environment: Arduino IDE Firmware: Marlin Host software:printrun Repetier-Host
1.3 Source
Arduino ide:http://www.geeetech.com/wiki/index.php/Download
Marlin:http://www.geeetech.com/wiki/images/3/39/Marlin-Marlin_v1.zip
printrun: http://www.geeetech.com/wiki/images/e/e1/Printrun-Win-Slic3r-10Mar2014.zip
Repetier-Host: http://www.geeetech.com/wiki/images/3/36/SetupRepetierHost_1_00.zip
2 Interfaces
2.1 Interface Layout
2.2 Interface specifications
1.DC IN: 12V 12A and 12V 5A 2.HOT_BED:heat bed 3.HEATER1: power supply for extruder 1 4.HEATER2: power supply for extruder 2 5.LCD ENCODER: LCD panel 6.SD Card 7. X_MIN/X_MAX/Y_MIN /Y_MAX /Z_MIN /Z_MAX: 6 end stop input 8. TEMP1: temperature sensor for extruder 1 9. TEMP2: temperature sensor for extruder 2 10. TEMP3: temperature sensor for heatbed 11. X,Y,Z:Stepper motors for X, Y, Z axis 12. EXT1, EXT2(A):Stepper motors for extruder 1 and extruder 2 13. FAN1,FAN2,FAN3:3 12V cooling fans 14. PWM: PWM output for cooling fan
2.3 subdivision of stepper motor
2-2
Turn ON/OFF            Subdivision
MS1    MS2    MS3
OFF    OFF    OFF     full step
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
ON     ON     ON     1/16 step
MS1    MS2    MS3
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
OFF    OFF    ON     1/16 step
ON     OFF    ON     1/32 step
OFF    ON     ON     1/32 step
ON     ON     ON     1/32 step
3 Development Environment setting
3.1 Interface Connecting and Setting
Note: Pay attention to the Plus-n-Minus of the power connector, reverse connection can cause irrevocably damages.
3.2 Software setting
3.3 File Burning Windows users need install driver before uploading. The board: Tools > Board > Arduino Mega 2560 or Mega ADK, as shown below.
Load in the file you need to burn, Click the “check ( )” button to check if it is right and then click the “ ” button to upload
firmware, as shown below.
4 Get Started
  1. define BAUDRATE 250000
  1. define MOTHERBOARD 7
  1. define TEMP_SENSOR_0 1
  2. define TEMP_SENSOR_BED 1
  1. define EXTRUDE_MINTEMP 170
  1. define INVERT_X_DIR false
  2. define INVERT_Y_DIR true
  1. define X_HOME_DIR -1
  2. define Y_HOME_DIR -1
  3. define Z_HOME_DIR -1
  1. define X_MAX_POS 205
  2. define X_MIN_POS 0
  3. define Y_MAX_POS 205
  4. define Y_MIN_POS 0
  5. define Z_MAX_POS 200
  6. define Z_MIN_POS 0
  1. define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0}
  1. define DEFAULT_AXIS_STEPS_PER_UNIT {85.3333, 85.3333, 2560, 158.8308}
verifying, you should delete the “//” from “//#define REPRAP_DISCOUNT_SMART_CONTROLLER” to ensure the normal working.
5 FAQ
1, How many extruders can GT2560 support? At most 2 extruders, GT2560 supports 5 A4988 stepper motor drivers, they are X/Y/Z axis and 3 extruders. 2. What is the Power Requirement of GT2560? It is 12V 12A for the heatbed and 12V 5A for the logical part.
6 How to get
Visit here now!
