Iduino Yun Shield
Revision as of 01:07, 27 January 2015 by Admin (talk | contribs) (Upload Sketch)
  • Open source Linux system (OpenWrt) inside
  • Low power consumption
  • Compatible with Arduino IDE 1.5.4 or later versions. Users can program, debug or upload Sketch to Arduino board
  • Managed by Web GUI, SSH via LAN or Wifi
  • Support internet connection via LAN port, Wifi or 3G dongle
  • Support USB flash to provide storage for Arduino projects
  • Reliable design provides robust system
  • Compatible with Arduino Leonardo, Uno, Duemilanove, Diecimila and Mega
Overview and Hard ware Resources
  1. Processor: 400MHz, 24 MIPS
  2. Flash: 16MB
  3. RAM: 64MB
  4. Power input: 4.75V~23V via Arduino Vin pin
  5. 1×10M/100M RJ45
  6. Connector 150M Wifi 802.11 b/g/n
  7. External antenna via I-Pex
  8. 1×USB port for USB storage or 3G connection
  9. 1×Reset button
  10. Compatible with 3.3V or 5V I/O Arduino
Size: 70mm * 53mm*24mm
Weight: 33.2g
Software Resource
Source
Interface layout
Interface specifications
  • RJ45, Wifi, USB port and Failsafe are connected to the Iduino Yun module directly, and the Iduino Yun module uses SPI and UART to communicate with Arduino board
  • The SPI interface is used to upload the sketch coming from the Arduino IDE. SPI interface connects to Iduino Yun only in the upload time, so the Arduino SPI can still be used to connect to the other slave devices.
  • The pins of two sides are respectively connected to the corresponding pins of Arduino
Getting IP address
Factory IP of Wifi port
FallBack IP
If the user’s laptop IP is
Detect IP from Arduino IDE
Allocation pattern
Webpage access
webpage access
SSH Access
SSH access
SSH Access:
Port: 22
User Name: root
Password: iduino (default)
Webpage Setting
General setting
Settings of Iduino
Upgrade
upgrade
upgrade
Use with Arduino Board
  1. Whether the Arduino board is powered by DC jack;
  2. If the board type setting is correct in the Iduino_Yun_Shield;
  3. If the board type setting is correct in the Arduino IDE;
  4. Whether the Arduino SPI and UART is not influenced by other hardware
  5. Make sure the UART mode is in Arduino Bridge.
Connect to Arduino Board
Connect to Leonardo
Connect to Arduino Uno
connect to arduino uno
unoyun.name=Arduino Uno --Iduino Yún
unoyun.upload.via_ssh=true
unoyun.vid.0=0x2341
unoyun.pid.0=0x0043
unoyun.vid.1=0x2341
unoyun.pid.1=0x0001
unoyun.upload.tool=avrdude
unoyun.upload.protocol=arduino
unoyun.upload.maximum_size=32256
unoyun.upload.maximum_data_size=2048
unoyun.upload.speed=57600
unoyun.upload.disable_flushing=true
unoyun.upload.use_1200bps_touch=true
unoyun.upload.wait_for_upload_port=true
unoyun.bootloader.tool=avrdude
unoyun.bootloader.low_fuses=0xff
unoyun.bootloader.high_fuses=0xde
unoyun.bootloader.extended_fuses=0x05
unoyun.bootloader.file=optiboot/optiboot_atmega328.hex
unoyun.bootloader.unlock_bits=0x3F
unoyun.bootloader.lock_bits=0x0F
unoyun.build.mcu=atmega328p
unoyun.build.f_cpu=16000000L
unoyun.build.board=AVR_YUN
unoyun.build.core=arduino
unoyun.build.variant=standard
connect to Arduino Duemilanove/Diecimila
Connect to Arduino Mega2560
connect to mega2560
mega2560Yun.name=Arduino Mega 2560 -- Iduino Yún
mega2560Yun.upload.via_ssh=true
mega2560Yun.vid.0=0x2341
mega2560Yun.pid.0=0x0044
mega2560Yun.vid.1=0x2341
mega2560Yun.pid.1=0x003f
mega2560Yun.upload.tool=avrdude
mega2560Yun.upload.protocol=arduino
mega2560Yun.upload.maximum_size=258048
mega2560Yun.upload.maximum_data_size=8192
mega2560Yun.upload.speed=57600
mega2560Yun.upload.disable_flushing=true
mega2560Yun.upload.use_1200bps_touch=true
mega2560Yun.upload.wait_for_upload_port=true
mega2560Yun.bootloader.tool=avrdude
mega2560Yun.bootloader.low_fuses=0xff
mega2560Yun.bootloader.high_fuses=0xd8
mega2560Yun.bootloader.extended_fuses=0xfd
mega2560Yun.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
mega2560Yun.bootloader.unlock_bits=0x3F
mega2560Yun.bootloader.lock_bits=0x0F
mega2560Yun.build.mcu=atmega2560
mega2560Yun.build.f_cpu=16000000L
mega2560Yun.build.board=AVR_MEGA2560
mega2560Yun.build.core=arduino
mega2560Yun.build.variant=mega
Detect Iduino_Yun_Shield
detect Iduino_Yun_Shield
Upload Sketch
upload sketch
Example
Say hello to Linux
Code:
String name;
voidsetup() {
Bridge.begin();
Console.begin();
while (!Console);
void loop() {
if (c == '\n') {
Console.print("Hi ");
Console.print(name);
Console.println();
name = "";  // clear the name string
Else {  // if the buffer is empty Cosole.read() returns -1
Test Interface:
test interface
In Hardware Aspect
In Software Aspect
  3. If the Iduino_Yun_Shield boots in advance than Arduino IDE, this situation may happen. So try to reboot the Iduino_Yun_Shield and check again.
User name: root
Protocol: SCP
How to reset Iduino_Yun_Shield?
  1. If pressing the toggle button and release after 5 seconds, it will reset the Wifi setting and other settings will be kept.
  2. If pressing the toggle button and release after 30 seconds, it will reset all the settings to factory default.
Set up TFTP service
Download Hercules utility
Protocol: UDP
Module IP: 192.168.255.1
Port: 6666
Local Port: 6666
Connect the PC to Iduino_Yun_Shield
Power up Iduino_Yun_Shield to Failsafe mode
Upgrade Kernel
tftpboot 0x81000000 ms14-arduino-yun-kernel-xxx.bin
erase 0x9fea0000 +0x140000
Upgrade rootfs
tftpboot 0x81000000 ms14-arduino-yun--rootfs-squashfs-xxx.bin
erase 0x9f050000 +0xe50000
Reset to the new firmware
Reset
Warning: User should use correct address in the erase and cp.b. Wrong address may destroy the boot-loader of Iduino_Yun_Shield and the device won’t boot anymore, or destroy the radio data leading to a poor Wifi performance or incorrect MAC address.
reset firmware
How to get it
