Me Creator
  • High Cost-Effective
  • Resolution up to .1mm
Operation
Placement
Connectivity
Make sure the heating plate and extruder are not heated when starting software. Power
We recommend plugging your Me Creator printer into a surge protector with a circuit breaker. Never attempt to open or fix your power supply. If you believe your power supply is not working properly, contact us asap.
Modifications
Warnings
Install the drivers
Windows
Windows 8
Windows Manual Install
Note: In some cases the drivers will not install on their own. The Solidoodle drivers for Windows can be found in the following link: Media:Serial install.zip
1) Download and install: Repetier Host Installer
2) Plug the power cord into a wall outlet and the Solidoodle USB cable into a USB port on your computer. Windows should detect your motherboard and assign the appropriate driver.
3) Open Repetier Host and Connect to your Solidoodle!
Click on the Manual Controls Tab and click in a direction X or Y to test your connection. If you are having difficulty connecting, please review the following supportive documentation: Installing Drivers and How to connect Please note that if you had difficulty connecting, there might have been an issue with the installation process. Ensure that the following have been installed:
Download and install the Serial Driver. For unsigned driver issues in Windows 8, please click here Download and install Microsoft .netFrameWork 3.5
