APM 2.52 Flight Controller Board
APM is a open source flight control system, it is a multifunction system that can support quadrocopter, as well as aircrafts of fixed -wing, three-axis, 6-axis,8 –axis etc. APM flight control is a rather mature technique with formidable capabilities: it supports GPS designated cruise and automatic return; supports data transmission to realize the remote receiving of real-time data from the aircraft; supports pan-tilt control technique of professional cameras to ensure anti-vibration aerial photograph; supports peripheral interfaces as airspeed meter and galvanometer to ensure stable flight and low voltage protection of voltage detection in real time.
The APM2.52 Control Board is used for make UAV. This version is ready to use, with no assembly required. It allows the user to turn any fixed, rotary wing or multirotor vehicle (even cars and boats) into a fully autonomous vehicle, capable of performing programmed GPS missions with waypoint.
1.High quality autolevel and auto altitude control – fly level and straight. Or fly the awesome "simple flight" mode.
2.No programming required. Just use an easy-to-use desktop utility to load the software with one click and set up ArduCopter with quick visual displays.
3.Unlimited GPS waypoints. Just point and click waypoints in the Mission Planner, and ArduCopter will fly itself to them. No distance limits! You can script entire missions, including camera control!
4."Loiter" anywhere. Just flip the toggle switch and your copter will hold its position using its GPS and altitude sensors.
5.Return to launch. Set home to any location and flip a switch to have ArduCopter fly back automatically.
6.Do all mission planning via a two-way wireless connection option. Waypoints, mode changing, even changing the gains of every control parameter can be done from your laptop, even while the copter is in the air!
7.Automatic takeoff and landing. Just flick a switch and watch ArduCopter execute its mission completely autonomously, returning home to land by itself in front of you when it's done.
Hardware Specification
APM2.52 Hardware Configuration
- ATMEGA2560 microcontroller
- MPU6000 3-axis gyroscope and 3-axis accelerometer
- MS5611 pressure sensor
- HMC5883L 3-axis Magnetometer
NOTE:
Your APM 2.5 board is designed to be powered by the included Power Module via the Power Port connector. You can, however, power it from an ESC or some other external 5v source, although that can be less reliable. If you do choose to use an alternative power source, you need to put the little jumper that came in the bag on JP1 pins, next to the "new diode" marked at the left above. If you are not powering the board from an external source, the JP 1 jumper should be off (this is the normal configuration) If you want to explore other alternative power schemes, a guide is in the Appendix here.
Assembly
- Assemble your ArduCopter frame
You can built your frame by yourself or buy it from http://store.3drobotics.com/
- Connecting your RC input and motors
More details refer to http://code.google.com/p/arducopter/wiki/APM2RC
- Install Mission Planner and download firmware
More details refer to http://code.google.com/p/arducopter/wiki/AC2Installation
- Configure RC and Fight Mode
More details refer to http://code.google.com/p/arducopter/wiki/AC2_First
Flying
Flight Test Process
! Warning ! Read This Safety Section Before Flying - [1]Bold text
To Test Loiter and Altitude Hold:
APM Mission Planner GCS
LED Describtion
- LED A:It gleamed on behalf of the flight control is Disarm (inactive) state, shake will not start the motor control device of throttle. Only keep the remote controller rudder to the right more than 4 seconds to activate A light into light, said the current in the activated state, can fly. In debugging, moves on the ground, to ensure that A lamp in A blink state, lest appear dangerous.
- LED B:Ignore
- LED C: Indicates the status of GPS.If the satellite positioning, GPS has found and the LED light.We haven't the GPS positioning, flicker;If there is no GPS, the lights go out.Using GPS flight, should be after electrify until a blue light and then take off.
- LED RX TX:In data transmission when rapid flashing, such as ground station software connected with USB cable and computer, or when digital radio communication;
- LED Alive:Whether power or USB connect,it will light all the time.
Documents
3-axis Gyro
3-axis Accelerometer
3-axis Digital Compass
High Resolution Altimeter
