Raspberry Pi Model B+
Revision as of 08:59, 5 August 2014 by Admin (talk | contribs) (Created page with "==Description== Raspberry pie is a portable, powerful,and mini computer. The board length is only 85mm and width is only 56mm.Its size only as big as a credit card but it is...")
Raspberry pie is a portable, powerful,and mini computer. The board length is only 85mm and width is only 56mm.Its size only as big as a credit card but it is a capable little PC. It can be used for many of the things that your desktop PC does, like high-definition video, spreadsheets, word-processing, games and more. Raspberry Pi also has more wide application range, such as music machines, parent detectors to weather stations, tweeting birdhouses with infra-red cameras, lightweight web server, home automation server, etc. It enables people of all ages to explore computing, learn to program and understand how computers work. The Raspberry Pi Model B+ provides more GPIO, more USB than Model B. It also improves power consumption, audio circuit and SD card. It is more useful for embedded projects.
Compare with Model B
The Model B+ is the higher-spec variant of the Raspberry Pi. Compared to the Model B it has:
  • More GPIO. The GPIO header has grown to 40 pins, while retaining the same pinout for the first 26 pins as the Model B.
  • More USB. We now have 4 USB 2.0 ports, compared to 2 on the Model B, and better hot plug and over current behavior.
  • Micro SD. The old friction-fit SD card socket has been replaced with a much nicer push-push micro SD version.
  • Lower power consumption. By replacing linear regulators with switching ones we’ve reduced power consumption by between 0.5W and 1W.
  • Better audio. The audio circuit incorporates a dedicated low-noise power supply.
  • Neater form factor. We’ve aligned the USB connectors with the board edge, moved composite video onto the 3.5mm jack, and added four squarely-placed mounting holes.
  • Chip: Broadcom BCM2835 SoC
  • Core architecture: ARM11
  • CPU: 700 MHz Low Power ARM1176JZFS core
  • GPU: Dual Core VideoCore IV
     Open GL ES 2.0, hardware-accelerated OpenVG, 1080p30 H.264 high-profile decode
     Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and DMA infrastructure
  • Memory: 512MB SDRAM
  • Operating System: Boots from Micro SD card, running a version of the Linux operating system
                  Supports Debian GNU/Linux, Fedora, Arch Linux, RISC OS and More
  • Power: Micro USB socket 5V, 2A
  • Ethernet: 10/100 BaseT Ethernet socket
  • Video Output: HDMI (rev 1.3 & 1.4)
              Composite RCA (PAL and NTSC)
  • Audio Output: 3.5mm jack, HDMI
  • USB: 4 x USB2.0 Ports with up to 1.2A output
  • GPIO Interface: 40-pin 2.54 mm (100 mil) expansion header: 2x20 strip
                Providing 27 GPIO pins as well as +3.3 V, +5 V and GND supply lines
  • Camera Interface: 15-pin MIPI Camera Serial Interface (CSI-2)
  • JTAG: Not populated
  • Display Interface: Display Serial Interface (DSI) 15 way flat flex cable connector with two data lanes and a clock lane
  • Memory Card Slot: SDIO
Dimensions
85mm x 56mm x 17mm
Includes
  • Raspberry Pi Model B+ Board x1
  • Instruction card x1
