Metal J-head short-distance
Revision as of 08:30, 18 June 2014 by Admin (talk | contribs) (Created page with "== Description == 450px All metal enables working with Polycarbonate up to 300 degrees Celsius and with future materials that require higher working t...")
This product adopts high-quality aluminum alloy heat radiator and brass nozzle, with stainless steel pipe as feeding pipe, which ensures good heat insulation effect and prevents blockage. Besides, its surface is covered with anodic oxide coating, which can resist oxidation corrosion and increase nozzle hardness, thus ensuring better heat insulation, stronger corrosion resistance as well as finer and more stable printing.
Feature
Configurable cooling fan, cooling effect.
Product Introduction
Printing resolution 0.1mm
Molding form FDM
Material Metal
Nozzle temperature 180℃-240℃
Outline dimensions 70*25*25mm L/H/W)
Weight 68g
Input voltage default to 12V
Cartridge heater 12V 30W
