EP2C5T144C8
Revision as of 02:29, 9 April 2014 by Admin (talk | contribs)
Time to build your real-time MIDI instrument/music player! It can play many format including MP3,WMA,WAV,AAC,MIDI,Ogg VorbisThe. Music Shield is an audio encoder/decoder compatible with Arduino, iduino mega and Arduino Mega. It is based on the VC1053B chip, which enabled it to play sound files from SD card and do short-time recording as well. You can also use it to play MIDI notes by slightly changing its hardware installations. Due to the SPI communication mode, it keeps a minimum number of IO port that facilitates users’ own developments of this device. Additionally, the new multifunction button provides greater convenience for users to control.
Notice: The recording function works with iduino Mega and Arduino Mega only. And the maximum size SD card you can use is 2GB.
I/O Configuration
