Crazyflie
Revision as of 01:56, 20 November 2013 by Admin (talk | contribs) (Created page with "1 Introduction 2 Packaging list 3 Hardware Specification 4 Features 5 Usage 6 Update firmware == Introduction == The Crazyflie is a tiny quadcopter o...")
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter
  • A crazyradio
3 Start to flying
  • Start up the application
  • Press Connect
