Iduino DUE
Note:The program will not run until you press the key of reset when you first fire program for the DUE from Native USB Port in sometime.
- Operating Voltage: 3.3V
- Min-Max Input Voltage: 6-20V
- Analog Input Pins: 12
- Analog Outputs Pins: 2
- Clock Speed: 84 MHz
Documents:
