Teensylu
- Logic supplied by USB bus
- on-board USB connectivity
- UART1 (RX and TX)
- I2C (SDA and SCL)
- SPI (MOSI, MISO, SCK)
- PWM pin (1)
- Analog I/O (6)
Compatible Firmwares
- Sprinter
- Marlin
- Repetier
Building and Programming the Firmware (applying to the AT90USB1286 preinstalled the LUFA HID bootloader)
- Download the arduino environment and install. http://arduino.cc/en/Main/Software
- Download the Teensyduino library from pjrc and install. Be sure to select "all" when asked which additional libraries to install
- Replace the avrdude.exe located in arduino-0023\hardware\tools\avr\bin with this version avrdude() and better backup the original avrdude.exe which has been replaced, otherwise uploading error will appear.If you have installed the Teensyduino library in Arduino 1.0 or higher version, skip this step
- Add the following to arduino-xx/hardware/teensy/boards.txt file at the bottom:
cdcteensylu.name=[BootloaderCDC]Teensylu/Printrboard cdcteensylu.upload.protocol=avr109 cdcteensylu.upload.maximum_size=130048 cdcteensylu.build.mcu=at90usb1286 cdcteensylu.build.f_cpu=16000000L cdcteensylu.build.core=teensy cdcteensylu.build.define0=-DUSB_SERIAL cdcteensylu.build.define1=-DLAYOUT_US_ENGLISH cdcteensylu.upload.speed=115200
- Download Sprinter firmware. https://github.com/kliment/Sprinter
- Open Sprinter in arduino and configure configuration.h file.
- Motherboard should be set to 8: #define MOTHERBOARD 8
- Turn off endstops if you didn't install endstops: const bool ENDSTOPS_INVERTING = true;
- Turn comment out SD card support, not working yet: //#define SDSUPPORT
- Remove the HWB jumper on the board to boot into the bootloader.
- Connect the USB cable to Teensylu, the virtual serial port appears. Remember this Serial port number, because this port is for only for communication, not for programming.
- Push the Reset button, the serial port number changes. This serial port is what we want for programming the firmware.
- Select the board Teensylu/Printrboard and uploding your firmware.
Sprinter(compatible for Arduino 023)
- Go to Tools menu and set Board to Teensy++ 2.0, or Teensylu if using alternate bootloader
- Go to Sketch menu and click "Verify/Compile"
- A program will popup for the teensy programmer after sprinter is done compiling
- open the HEX File in teensy loader and move sprinter.cpp.hex to root folder of C drive for programming
Windows
- Windows will find the new hardware as the virtual com port. If windows find the unrecognized hardware, install the USB Serial driver
- Install the WinAVR
Schematics
Burn the bootloader
Click here to buy Teensylu
