Tiny6410
Tiny6410 | S3C6410 ARM11 Stamp Module
FriendlyARM Tiny 6410 Stamp Module with 533 MHz Samsung S3C6410 ARM11 processor.
Specification: Stamp Module
- Dimension: 64 x 50 mm
- CPU: 533 MHz Samsung S3C6410A ARM1176JZF-S with VFP-Unit and Jazelle (max freq. 667 MHz)
- RAM: 128 MB / 256 MB DDR RAM, 32 bit Bus
- Flash: 256 MB / 1GB NAND Flash
- Serial, SPI, USB, LCD, CMOS Camera *Analog Input and Output
- User Outputs: 4x LEDs
- Expansion headers (2.0 mm)
- Debug: 10 pin JTAG (2.0 mm)
- OS Support
- Windows CE 6
- Linux 2.6
- Android
- Ubuntu
Specification: SDK-Board
- Dimension: 180 x 130 mm
- EEPROM: 1024 Byte (I2C)
- Ext. Memory: SD-Card socket
- Serial Ports: 4x DB9 (RS232)
- IR: Infrared Receiver
- USB: 1x USB-A Host 1.1, 1x miniUSB Slave 2.0
- Audio Output: 3.5 mm stereo jack
- Audio Input: 3.5mm jack
- Ethernet: RJ-45 10/100M (DM9000)
- RTC: Real Time Clock with battery
- Beeper: PWM buzzer
- TV Output: CVBS
- LCD: 40 pin (2.0 mm) and 41 pin connector for FriendlyARM Displays and VGA Board
- Touch Panel: 4 pin (resistive)
- User Inputs: 8x buttons and 1x A/D pot
- Power: regulated 5V (DC-Plug: 1.35mm inner x 3.5mm outer diameter)
Stamp Module
DK-Board + Stamp Module
Click here:http://www.geeetech.com/armavr-series-arm11-c-9_52.html
