SHARP IR Ranger Sensor GP2D12 for Arduino
Revision as of 02:07, 25 May 2012 by Admin (talk | contribs) (Created page with "==Introduction== File:GP2D12 1.jpg The Sharp GP2D12 is an analog distance sensor that uses infrared to detect an object between 10 cm and 80 cm away. The GP2D12 provides ...")
The Sharp GP2D12 is an analog distance sensor that uses infrared to detect an object between 10 cm and 80 cm away. The GP2D12 provides a non-linear voltage output in relation to the distance an object is from the sensor and interfaces easily using any analog to digital converter.
  • Measuring range : 10 to 80 cm
  • The maximum allowable Angle : > 40 °
  • The power supply voltage : 4.5 to 5.5 V
  • The average power consumption : 35 mA
  • Peak power consumption : about 200 mA
  • The frequency of updates/cycle : 25 Hz/40 ms
  • Analog output noise : < 200 mV
SHARP GPD2D12 datasheet
Pinout
Here is the guide illustrates how to connect an Arduino to the ADXL335 breakout board.
char GP2D12;
char a,b;
 Serial.begin(9600); //
 int val;
 GP2D12=read_gp2d12_range(0);
 a=GP2D12/10;
 b=GP2D12%10;
 val=a*10+b;
 if(val>10&&val<80)
   Serial.print(a,DEC);//
   Serial.print(b,DEC);//
   Serial.println("cm");//
 else Serial.println("over");//
 delay(50);
float read_gp2d12_range(byte pin)
 int tmp;
 tmp = analogRead(pin);
 if (tmp < 3)return -1;
 return (6787.0 /((float)tmp - 3.0)) - 4.0;
Click here to buy SHARP IR Ranger Sensor GP2D12
