Arduino ENC28J60 Ethernet Module
Revision as of 02:56, 21 May 2012 by Admin (talk | contribs)
  • Brand New and High Quality
  • With this Ethernet Shield, your Arduino board can be used to connect to internet
  • Genuine Microchip's ENC28J60 SPI ethernet controller and HR911102A RJ45 socket
  • Open-source TCP/IP protocol stack as an Arduino library.
  • Web client application to use Arduino as a distributed network sensor
To get it work, ENC28J60 library need to be used.Due to the function name of ENC28J60 library is same as the original Ehernet libray, the original Ethernet library in the library folder must be removed.
Open Arduino IDE Files - Examples - ENC28J60 - WebServer
