Metal J-head V2.0 long-distance
This product adopts high-quality aluminum alloy heat radiator and brass nozzle, with stainless steel pipe as feeding pipe, which ensures good heat insulation effect and prevents blockage. Its surface is covered with anodic oxide coating, which can resist oxidation corrosion and increase nozzle hardness and surface area of heat radiator. Besides, the cooling fan directly faces to operation area. All such special designs ensure better heat insulation as well as finer and more stable printing.
Product Introduction
Printing resolution | 0.1mm |
Molding form | FDM |
Material | Metal |
Nozzle diameter | [0.3], [0.35], [0.4] , [0.5] optional |
Movement speed | 50cc |
Outline dimensions | 84*43*58mm L/H/W |
Weight | 140g |
Cartridge heater | 12V 30W |
Click here to buy Metal J-head V2.0 long-distance
