Geeetech Mizar S 3D Printer
Product details
Unpacking and proper handling
Slicing
Printer maintenance
How to replace a hotend
Wrench size 10 mm
Step 1 Preparing
Remove the strain gauge.
Fix the new strain gauge.
Install the new hotend.
Step 5 Install the PTFE tube
Tweezers for nozzle
Step 1 Clean the hotend
Step 2 Replace a nozzle
Turn the printer off.
Allen keys – 2.5/3 mm
Disconnecting all the cables.
Connect the LCD cable.
How to replace PSU
Allen keys - 2.5/3 mm
Assembling the new PSU.
Tighten the two screws.
How to replace a hotbed
Allen keys – 3 mm
Tighten the three screws.
How to replace a screen
Allen keys - 2.5/3 mm |
Turn the printer off and unplug the power cable.
