Geeetech Mizar S 3D Printer
Product details
Unpacking and proper handling
Slicing
Printer maintenance
How to replace a hotend
Wrench size 10 mm
Step 1 Preparing
Tweezers for nozzle
Allen keys – 2.5/3 mm
How to replace PSU
Allen keys - 2.5/3 mm
How to replace a hotbed
Allen keys – 3 mm
How to replace a screen
Allen keys - 2.5/3 mm |
