Geeetech Mizar S 3D Printer
Product details
Unpacking and proper handling
Slicing
Printer maintenance
How to replace a hotend
Wrench size 10 mm
Step 1 Preparing
Preheat the nozzle to 220 Celsius from the LCD menu.
Remove the hotend housing.
Disconnect the hotend thermistor.
Release and remove the two screws that secure the hotend.
Remove the cables on the extension board.
Remove the strain gauge.
Cut the zip ties.
Tweezers for nozzle
Allen keys – 2.5/3 mm
How to replace PSU
Allen keys - 2.5/3 mm
How to replace a hotbed
Allen keys – 3 mm
How to replace a screen
Allen keys - 2.5/3 mm |
