Geeetech Thunder 3D printer
Revision as of 07:56, 16 August 2022 by Admin (talk | contribs)
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
Cura Configuration File
User Mode Introduction
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Thunder
Nozzle discharge abnormality
First layer abnormal
Layer shift
