Me Creator
- High Cost-Effective
- Resolution up to .1mm
Technical Specifications
Physical Dimensions
Printing Specifications
Layer Resolution:0.1mm
Filament Type:ABS, PLA
Filament Diameter:1.75mm
Nozzle Diameter:0.3mm
Temperature
Max Heated Bed Temp:0-110 ℃
Max Extruder Temp:0-250 ℃
Electrical
Power Requirement:120W
Connectivity:USB
Mechanical
Chassis:Steel Frame
Build Platform:Aluminum
Operation
Placement
Connectivity
Modifications
connect power supply
1.Take out the powersupply unit, check the condition of it and check it is 220V or 110V, you can switch it according to your real situation. this is very inportant.
2. Loose the screws on the connector,then screw the wires up in order, you can refer to the color of the wire, as shown in the following picture.
L -- brown
N -- blue
GND -- yellow
COM -- black
+ V -- red
Install the drivers
Windows 8
Windows Manual Install
Macbook
How To Connect
In Mac, you should finish step 5&6 in "Printer>Printer settings", step 4 is unnecessary
slic3r setting test
2. you can see the slicer confirure pannel now.
3.Now you can load the ini file into the slicer or configure the parameters one by one, firt let's see how to load the file.
4. Find the ini file in your computer. and you can see the parameters changed accordingly.
Leveling The Print Bed
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
How to control on LCD
- Press the button>”Prepare”>”Move axis”>”Move 10mm/1mm/0.1mm”>”Move X/Y/Z/extruder”>Rotate the button>Press the button
Unblocking Procedures
Types of Blocks
- The Stubborn Filament
- Filament broke mid print
Tweezers
Dental Pick
Filament
Long Skinny Metal Object
The Cold Block
- Identification
- Solution
The Hot Block
- Identification
- Solution
- Solution 1: Break the block
Alternative: Acetone bath
Cleaning the Drive Gear
detailes of me creator
heatbed -
Belts of x,y axis -
Belt of z axis -
MK8 extruder -
Print carriage
where to get
