3.2TFT LCD
Revision as of 02:57, 12 April 2012 by Admin (talk | contribs) (Usage:)
introduction
HY-TFT320 is a 3.2 inch TFT LCD Screen module, 320*240 (resolution), 65K color, 40pins interface , not just a LCD breakout, but include the Touch screen, SD card. So it’s a powerful extension module for your project.
Application Ideas
  • Digital Photo Frame (DPF)
  • Video terminals
  • Instrumentation
  • GPS
  • Game consoles
Specification:
  • 3.2" Color TFT LCD
  • 320 x 240 Resolution
  • 65,536 Colors (16 Bit)
  • Built-in video RAM buffer
  • Integrated SD card
  • 5V Operating Voltage
  • LED Backlight
pin difinition
Usage:
500
Display:
The TFT library is required to be installed to get this screen model display. This library is especially designed for 3.2” TFT LCD screen using 16 bit mode. The library require the following connections.
LEDA -> 5V
VCC -> 5V
RD -> 3.3V
GND -> GND
DB0->DB7 to pin D37->D30
DB8->DB15 to pin D22->D29
RS -> D38
WR -> D39
CS(pin6) -> D40
RSET-> D41
Note: The TFT controller model needs to be declared in the initializing statement. ITDB02 myGLCD(38,39,40,41) needs to be modified as myGLCD(38,39,40,41,ITDB32S), otherwise it just show a blank screen. In practice, RS, WR, CS, RSET can be connected to any free pin. But the pin number must be in accord with myGLCD(RS,WR,CS,RST).
Touch Screen:
The LCD has a 3.2" 4-wire resistive touch screen lying over it. The Touch library needs to be installed to get it works. This library is designed for 2.4’’ TFT, 3.2” TFT LCD screen module.
Interface the touchscreen to Arduino Mega Default pin number in example code:
DCLK-> D6
CS(pin30) -> D5
IN -> D4
OUT-> D3
IRQ -> D2
SD Card:
SCK -> D52
MISO -> D50
MOSI-> D51
CS -> D53
How to buy it
Click here to buy 3.2TFT LCD
