3.2TFT LCD
introduction
HY-TFT320 is a 3.2 inch TFT LCD Screen module, 320*240 (resolution), 65K color, 40pins interface , not just a LCD breakout, but include the Touch screen, SD card. So it’s a powerful extension module for your project.
Specification:
•3.2" Color TFT LCD •320 x 240 Resolution •65,536 Colors (16 Bit) •Powerful 16 Bit Microcontroller(SSD1289) •Built-in video RAM buffer •Integrated Resistive Touchscreen •Integrated SD card •5V Operating Voltage •LED Backlight
pin difinition
Connect HY-TFT320 to Arduino Mega2560:
Display:
The TFT library is required to be installed to get this screen model display. This library is especially designed for 3.2” TFT LCD screen using 16 bit mode. The library require the following connections.
LEDA -> 5V VCC -> 5V RD -> 3.3V GND -> GND DB0->DB7 to pin D37->D30 DB8->DB15 to pin D22->D29 RS -> D38 WR -> D39 CS(pin6) -> D40 RSET-> D41
Note: The TFT controller model needs to be declared in the initializing statement. ITDB02 myGLCD(38,39,40,41) needs to be modified as myGLCD(38,39,40,41,ITDB32S), otherwise it just show a blank screen. In practice, RS, WR, CS, RSET can be connected to any free pin. But the pin number must be in accord with myGLCD(RS,WR,CS,RST).
Touch Screen:
The LCD has a 3.2" 4-wire resistive touch screen lying over it. The Touch library needs to be installed to get it works. This library is designed for 2.4’’ TFT, 3.2” TFT LCD screen module.
Interface the touchscreen to Arduino Mega Default pin number in example code: DCLK-> D6 CS(pin30) -> D5 IN -> D4 OUT-> D3 IRQ -> D2
SD Card:
Interface SD card to Arduino mega: SCK -> D52 MISO -> D50 MOSI-> D51 CS -> D53
