Repetier-Host
Revision as of 02:57, 20 November 2015 by Admin (talk | contribs) (windows)
The Repetier-Host is a simple to use host software, which is be compatible with most firmwares around. You can add and position your STL files on the simulated printbed and slice them all together. For slicing you can use the built-in Slic3r slicer or use the well-known Skeinforge. Just call "Slice & Load" and the job gets delegated to the current slicer, showing its output in the log window. For a full description please visit the Repetier-Host homepage.
  • Easy to use GUI.
  • Easy to use Windows, Linux or Mac OS X installation.
  • Communicates in classic ASCII mode or using binary Repetier-Protocol.
  • Includes the fast Slic3r slicer.
  • Alternatively integrates Skeinforge as second slicer.
  • STL composer - place, rotate and scale your STL files on your printbed and store or slice it.
  • STL files are automatically converted to G-Code.
  • Visual preview of G-Code. You can even change the code and see the difference.
  • Syntax highlighting and code explanation.
  • Visualizes the G-Code sent to the printer.
  • Shows estimated print time.
  • Supports SD cards.
  • Simple control panel for tests.
  • Jobs can be changed in internal editor before being sent to the printer.
  • Supports multiple 3D printers.
  • Logs commands and responses.
  • Test generator for printer calibration.
Download
windows
The Windows installer comes already with everything you need. It includes Repetier-Server, Slic3r, CuraEngine, Skeinforge, Python and Pypy. Requires Microsoft .NET Framework 4.
Repetier-Host Windows 1.6.0
Older Versions for Windows:
Older versionsare not supported anymore and contain unfixed bugs and should be avoided when possible.
Repetier-Host 1.5.6
Repetier-Host 1.0.6
Mac
The latest stable release of the Repetier-Host for Macintosh comes already with everything you need. Download and run the package to install. If you are using the new Mountain Lion, you need to allow installation of unsigned code!
Repetier-HostMac 0.56
Older Versions for Mac: Older versionsare not supported anymore and contain unfixed bugs and should be avoided when possible.
Repetier-HostMac 0.53
Repetier-HostMac 0.51
Linux
The Linux installer comes already with everything you need. It includes Repetier-Server, Slic3r, CuraEngine, Skeinforge, Python and Pypy. A recent installation of the Mono framework (3.2 was tested to work with the latest release on Ubuntu 14.04) is required. After unpacking the tar file you need to run configureFirst.
Repetier-Host Linux 1.6.0
Older Versions for Linux: Older versionsare not supported anymore and contain unfixed bugs and should be avoided when possible.
Repetier-Host Linux 1.5.6
Repetier-Host Linux 1.0.6
