Geeetech Prusa I3 M201
The M201 features our newly engineered the 2-in-1-out switchable hotend, that feeds 2 filaments through one nozzle. With the new 2-in-1-out hotend the M201 can work like a color palette, providing a new level of expression with your prints allowing you to create alternating colors, blending color and gradients.
In order to achieve this we optimized the firmware that is driven by our newly developed GTM32 control system, which is based on the STM32 processor and paired with the ARM Coretex M3, running a dominant frequency of 72MHz, greatly improving the overall printing performance.
Blending color
In Mixer, you can custom the the feed rate proportion of the two filament to generate new colors, that is a kind of blending color. The sum feed rate of Filament 0 and Filament 1 is 100%. If you manually adjust either of the two values, system will automatically work out the other value. The proportion will not change unless you change it or choose other printing scheme. Different feed rate proportions can be used in one printing item.
Gradient color
In Mixer>Templates, we have prepared 4 pairs, 8 kinds of built-in gradient templates for you to choose to print items with gradient colors. In this scheme, the feed rate proportion of two filament will vary with the printing process, and the waxing and waning proportion of two filament is reflected on the inform screen, so you can estimate the time duration and prepare for the next templates.
Feature
Printing specifications
Print technology:FDM/FFF
Build volume: 280 x210x200mm
Print Speed: 60-110 mm/s
Filament diameter: 1.75mm
Nozzle diameter: 0.4mm
Filament type: PLA, ABS
File format: .STL,G-code
Temperature
Electrical Power supply:
Output:DC24V/0-15A
Mechanical
Physical Dimensions & Weight
Machine Net weight: 9.5kg
more details
Building instruction
Download the Building instruction here.
for instruction videos, please go to our youtube channel.
<iframe width="560" height="315" src="https://www.youtube.com/embed/videoseries?list=PLODCkot3GrihN2yzDrAGAwSVQ-cbIUObs" frameborder="0" allowfullscreen></iframe>
