Mini210
Mini210 | S5PV210 ARM Cortex-A8 Board
FriendlyARM Mini 210 SBC (Single-Board Computer) with 1 GHz Samsung S5PV210 ARM Cortex-A8 processor. The board measures 130 x 115 mm, ideal for learning about ARM Cortex-A8 systems.
- Dimension: 130 x 115 mm
- CPU: 1 GHz Samsung S5PV210 with PowerVR SGX540 graphics engine
- RAM: 512 MB DDR2 RAM, 32 bit Bus
- Flash: 1GB NAND Flash
- EEPROM: 256 Byte (I2C)
- Ext. Memory: 2x microSD-Card socket
- Serial Ports: 1x DB9 connector (RS232), total: 4x serial port connectors
- IR: Infrared Receiver
- USB: 1x USB-A Host 2.0, 1x miniUSB Slave/OTG 2.0
- Audio Output: 3.5 mm stereo jack, connector for a speaker (Class D Amp)
- Audio Input: Condenser microphone
- Ethernet: RJ-45 10/100M (DM9000)
- WiFi/WLAN: onboard SD-WiFi with ceramic antenna
- RTC: Real Time Clock with battery
- Beeper: PWM buzzer
- Camera: 2x 20 pin (2.0 mm) Camera interface
- TV Output
- Monitor: miniHDMI (type C)
- LCD Interface: 50 pin (2.0 mm) and 41 pin (1.0 mm) connector for FriendlyARM Displays
- User Inputs: 8x push buttons and 1x A/D pot
- User Outputs: 4x LEDs
- Expansion: 40 pin GPIO (ADC, I2S, I2C, SPI, PWM, IO...), 20 pin SDIO (SD, SPI, I2C), 20 pin Buttons (2.0 mm)
- Debug: 10 pin JTAG (2.0 mm)
- Power: regulated 5V (DC-Plug)
- OS Support
- Linux 2.6
- Android
