Geeetech G2 & G2s pro
Revision as of 00:58, 15 October 2015 by Admin (talk | contribs) (Related source)
introduction
This Rostock mini G2s pro upgraded delta 3D printer -Rostock mini G2s.
Compared to its predecessor, this G2s pro has two major merits, it looks cooler and it works better.
The printing effector of the G2s pro is upgraded with metal parts, which are more durable and stable than the prints. The whole machine is craft out of high-quality aluminum and laser cut acrylic plate, making it more stable and smooth when printing, improving the printing accuracy and speed to a higher level.
An metal auto-leveling device is also improved on G2s pro; which means you do not have to adjust it every time before you start printing, and with this new metal leveling device, the calibration will be more accurate.
In terms of printing filament, G2s pro not only supports PLA and ABS, Nylon and wood filament is also available, which enables more possibilities to create 3D printing project.
This G2s pro is powered by our newly designed control system—GT2560 that supports 2 extruders and eliminates the complicated wiring of Mega2560+Ramps 1.4 and it is more space-saving.
With G2s pro you can print a single two-color object, or you can print two objects in one print job, each made from a different color. You can also print one single-color object, as with other single-extruder 3D printers. Or you can use one extruder for infill or support.
This G2s pro is also improved with LCD control panel; you can monitor the printing process in real time and with a SD card it can realize stand-alone printing, very convenient.
Main features
1.All metal effectors for more stable and smooth printing.
2. With auto-leveling and auto-calibration features.
3. With dual extruder, support multiple way of printing.
4. Support PLA, ABS, Nylon and Wood, giving more possibilities to create 3D printing object.
5. New updated control system.
6. More fluent printing process and higher accuracy.
Related source
firmware
Slic3r config
Printing test file
