Delta Rostock mini G2
Main features
SOURCES
download the STL file for the printed parts hereMedia:Geeetech delta rostock mini G2 &G2s STL.rar
Print Volume: cylindrical,D:190mm,H:200mm
The Layer Thickness: 0.1mm
Layer Resolution: 0.1mm
Filament Diameter: 1.75, 3mm
Print Speed: 60 to 120 mm/sec
Print Plate Size: 210 x 3mm
XYZ Bearings: carbon steel
Output:DC12V/0-15A
No. of Extruders: 1
Electronics: GT2560
Machine weight:8.5kg
Shipping box weight:9.5kg
Building instruction
For detailed building instruction, please visit here, or you can download the PDF version .
Install drivers and software
Install the drivers
here.
Macbook (OS X) Manual Install
Click "Continue" in Read me.
Click "Continue" in License.
How to set up
How to modify and upload firmware
In the following set-up process, you will need to modify and upload the firmware by yourself, so, first of all, let’s start with the firmware comliling and uploading.
1. Download the firmware here:
Firmware for Delta Rostock mini G2
Firmware for Delta Rostock mini G2S
2. Connect GT2560 to your PC with a USB cable,install FTDI drive. Usually it will install automaticlly. If not you need to install maually.
3. If there is nothing wrong with the hardware of board, you can find COM port in device manager. But every computer has different COM watchword, you need check by yourself.
4. Unzip the firmware, drag all the files into Arduino IDE. I use Arduino1.0.5,choose Board\Arduino Mega or Mega2560,and selects ATmega2560(Mega2560) as default Processor. The order cannot be wrong. Selects the COM port you find in the device manager.
Find the value you need to comlile according to your printer. Upon compiling, you can upload the firmeare to your control board. Simply click veryfy and upload.
Printer preparing
2. To protect the bed and the nozzle from crashing, please attach a piece of tape on the bed.
Printer setting
Home X: 0,
Home Y: 0
Home Z: Max
Printer Radius: 100mm
Printable height: 200mm
Homing the printer
Homing is the first and foremostt hing you need to test. To home the printer, you can check if the three axis of the printer move in the same direction,if not, there will be crack for the spider and the carriage.
Before homing, you need to follow the next steps.
1.Go to printer setting> printer. Set the travel feed rate and the Z axis feed rate as 300 mm/min.
(Even though we have set the speed as slow as possible for you, you still need to adjust the feed rate. )
2.Hook up the probe with your hand, we are not testing the auto-leveling fuction right now.
3. Move the extruder head to the middle and be ready for emergency stop. You can click the emergency stop icon on the repetier host or shut the power supply directly.
4. Go to the Manual Control and click the home icon.
If the three axis move in the different directions, please check the conenction of the stepper motor wires.
Define the initial Z axis height
If the printer can home normally, the three axis move in the same directions, we can set the height of the Z axis now, but this value may not be the final height.
1. You can use a rule or digital graphics to measure. The height of the Z axis means the distance between the nozzle and the building platform after homing. So you need to measure after homing.
2. Or you can use maual control to move the Z axis down to the building platform till the nozzle just touches the bed. When moving the Z axis, please slow it down.
Move 0.1mm per click
3.Read the coordinates of the Z axis when the nozzle just touches the bed. E.g. if it is (0,0,1), then the Z axis height is 200-1=199。If it is (0,0,2) the height is 200-2=198.
(*200 is pre-set height in the firmware. 1 is the Z coordinate)
4. Open the firmware in IDE, locate the following code in IDE
//Manual homing switch locations:
  1. define MANUAL_HOME_POSITIONS // MANUAL_*_HOME_POS below will be used
// For deltabots this means top and center of the Cartesian print volume.
  1. define MANUAL_X_HOME_POS 0
  1. define MANUAL_Y_HOME_POS 0
  1. define MANUAL_Z_HOME_POS 200// For delta: Distance between nozzle and print surface after homing.
Then you can change the 200 into the height you got (e.g.205 or 199 you get) in the firmware and upload it.
Upon uploading the firmware, you need to change the printing setting in the Repetier host.
Home X: 0
Home Y: 0
Home Z: Max
Printable height: 205mm (* the height you put in the firmware)
Define the final Z axis height
Step1. Homeing the printer.
Step2. Tighten the screw trigger for each endstop, make sure they reach as long as possibl.
Adjust the screw on these 3 carridges.
Step3. Set 3 probing points (0,50)、(43.3,-25)、(-43.3,-25), using G-code command to adjust the print head to the 3 points and record the distance between the nozzle and the print surface separately.
3)send G 0 X-43.3 Y-25 Z2, record the distance;e.g. it is 2.2mm in my case.
You may need to adjust again and again till the three distance are the same or at least very close.
You are required to operate again and again till you get a satisfied result.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET+2.0
  • If the nozzle touches the center point but not the around points, that is a convex surface, you should reduce the DELTA_RADIUS from 2.0 to 1.0 for example.
  • If the nozzle touches the around points but not the center point, that is a concave surface, you should increase the DELTA_RADIUS from 2.0 to 3.0 for example.
So far, we can get the exact height of the Z axis.
check the status of endstop
* x_max,y_max,z_max is for the endstop:
if the endstop is triggered, the feedback is Triggered;
If the endstop is not triggered, the feedback is Open.
z_min is for the probe:
Trouble shooting:
Define the Z_PROBE_OFFSET
//these are the offsets to the probe relative to the extruder tip (Hotend - Probe), these values are very important, especially the Z_PROBE_OFFSET.
Then modify the Z_PROBE_OFFSET in the firmware and upload again.
slic3r configuration
printer setting
1. set bed shape.
in the latest version of Slic3r,V1.2.7, you can set the bed shape, this is very important when printing with your delta rostock mini. go to general manual, click set button, choose circular and fill in the diameter of the printer bed.
  • if your slic3r is not the latest version, you can update or download it here, unzip the file and drag them into the directory of your previour slic3r directory. do please delete the old version. Restart your Repetier and continue.
2.Start G29 Command
Calibration of auto-leveling
2.Send G29 command.
4.Hook up the probe manualy.
8.You may have to test it for more than once, but for the sake of better printing object,please be patient.
9.Once auto-leveling is set up, Hook up the probe manualy. Then you can print your first prints.
