Delta Rostock mini G2 Building Instruction
Preparation
Chapter1 Base Assembly
Motor end assembly
Stepper motor
53
3
Pulley
33
3
Motor holder
A3
3
Motor holder support
A4
6
Square nut
14
6
M3 X 12 Screw
18
12
M3 X 16 Screw
19
6
M3 washer
5
18
base plate
A2
1
Square nut
14
9
M3 X 16 Screw
19
9
M3 washer
5
9
Mount the LCD panel
LCD frame LCD frame
A8
1
LCD support
A9
2
LCD2004
54
1
Square nut
14
4
M3 X 16 Screw
19
4
M3 X 12 Screw
18
4
Spacer
34
4
M3 washer
5
8
Knob
55
1
Mount the fan
Fan(40x40x10)
45
1
M3 X 16 Screw
19
1
M3 x 25 screw
21
2
M3 Square nut
14
1
M3 nut
10
2
M3 washer
5
3
Mount the control board.
Control board GT2560
52
1
Spacer
34
4
M3 X 12 Screw
18
4
M3 washer
5
4
Mount the print bed.
Building platform
36
1
Heatbed
44
1
Hex Counter-sunk-head screw
15
3
Spring 3.5 x 20mm
27
3
Wing nut
13
3
M3 washer
5
6
Here is the finished picture.
Chapter 2 Top Plate Assembly
endstop mount
Top plate
A1
1
Endstop mount
A6
3
Endstop
49
3
Square nut
14
9
M3 washer
5
9
M3 X 16 Screw
19
9
Drive wheel mount
Drive wheel mount
A5
3
Driven wheel holder
32
3
624zz ball bearing
29
6
M3 X16 Screw
19
3
M3 X25 Screw
21
6
M4 X 25 Screw
25
3
M3 nut
10
6
M4 lock nut
12
3
Wing nut
13
3
M3 washer
5
15
Mount the extruder
Extruder
50
1
M5 x 16 screw
26
4
M5 washer
7
4
The screws are bottom - up.
Note: If your are assembly the G2s, you will need another 4 M5 x 16 screws and 4 washers to mount another the extruder.
Mount the spool holder
Spool holder Side panel
A10
1
A11
1
M3X16 screw
19
4
Square nut
14
4
Screw up the spool holder panel on the top plate separately with M3X16 screw and M3 nut and washer.
Through the spool holder rod into the panel, or you can do it later after you finish the building.
Chapter3 mount the smooth rods
Smooth Rod
1
6
Linear Bearing
30
6
M4 X12 Screw
23
12
M8 Washers
9
12
M4 washer
6
12
Diagonal Rod
1
6
rod-end bearing holder
3
6
Fan(30x30x10)
46
1
Hotend
51
1
Spider washer
P1
1
Hotend bracket
P2
1
Hotend half bracket
P3
1
Fan mount
P5
1
Carriage
P4
3
Automatic leveling
57
1
Zip tie
35
12
Round head screw with pad
16
12
M3 x 8 screw
17
12
M3 x 16 screw
19
6
M3 x20 screw
20
3
M3 x40 screw
22
3
M4 x 16 screw
24
2
3.5*30 spring
28
3
M3 nut
10
7
M4 nut
11
2
M3 washer
5
20
M4 washer
6
2
M6 washer
8
12
Assemble the spider
Step1. Insert the hotend into the half bracket, stack the hotend bracket and half bracket together, screw up with 4 M3 x 16 screws and M3 nut.
(Note: For your convenience, the hotend is assembled with heaters and sensors, so, please ignore the difference in the picture)
If you are building G2s, the steps are the same.
Step2. Screw the fan onto the fan mount with 2 M3x 20 screws.
Assemble the auto-leveling probe
Assemble the diagonal rods.
Step2. Repeat the above steps for the other diagonal rods. And mount another end of the diagonal rods to the spider.
The directions should be as shown in the following picture.
Chapter5 Mount the Belt
Timing Belt
1
3
*The belt should be neither too tight nor too loose, you can slide the carriage up and down to see if it is.
Chapter6 Connect the PTFE tube.
Feeding pipe
1
1
* If you need to pull the tube out, please press the blue part while pulling.
Chapter7 Wiring
4) Connect extruder
Step4. Connect heating wires.
endstop
41
3
Step6. Connect wires for Fan.
Power cable
48
1
3D Power cable
49
1
As shown in the red box.
Chapter8 Tidy out the wires
