Delta Rostock mini G2
Main features:
Specifications:
The Layer Thickness: 0.1mm
Layer Resolution: 0.1mm
Print Speed: 60 to 120 mm/sec
Print Plate Size: 210 x 3mm
XYZ Bearings: carbon steel
Output:DC12V/0-15A
No. of Extruders: 1
Electronics: GT2560
Machine weight: 7.5kg
Shipping box dimensions:
Shipping box weight:
building instruction
install drivers and software
Install the drivers
here.
Macbook (OS X) Manual Install
Click "Continue" in Read me.
Click "Continue" in License.
How to set up
Printer setting
Home X: 0
Home Y: 0
Home Z: Max
Printer Radius: 100mm
Printable height: 210mm
Start G29 Command
Printer preparing
3)send G 0 X-43.3 Y-25 Z2, record the distance;e.g. it is 2.2mm in my case.
  • If the nozzle touches the center point but not the around points, you should reduce the DELTA_RADIUS
  • If the nozzle touches the around points but not the center point, you should increase the DELTA_RADIUS
Modify the firmware of Delta
We have pre-loaded the firmware to GT2560 before shipping, but as this is a DIY printer, there may be some subtle difference between each printer, so you need to modify the firmware to fit your exact printer for better printing effect.
1. Download the firmware here. And unzip the zip/rar file.
2. Open Arduino IDE. ( If you do not have Arduino IDE, you can download here.)
3. Drag all the files into Arduino IDE.
4. Click Configuration.h and find out Delta Settings
 #define DELTA and modify the values as below.
Please pay close attention to the red numbers.
 // Make delta curves from many straight lines (linear interpolation).
 // This is a trade-off between visible corners (not enough segments)
 // and processor overload (too many expensive sqrt calls).
 107 #define DELTA_SEGMENTS_PER_SECOND 160
 110 #define DELTA_DIAGONAL_ROD  186【1】
 113 #define DELTA_SMOOTH_ROD_OFFSET 160.0 【2】
 116 #define DELTA_EFFECTOR_OFFSET 34.0【3】
 119 #define DELTA_CARRIAGE_OFFSET 25.0【4】
* To help you better understand the 4 values, you can refer to the scheme.
 // Horizontal distance bridged by diagonal push rods when effector is centered.
 122 #define DELTA_RADIU (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET+ 2.0)
 =160-34-25+2
 // Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
 125 #define DELTA_PRINTABLE_RADIUS 83
 // use the Z-min, if you connect a mechanical endswitch between Com and NO pins, you do not have to change the setting for the Z-min, however, if you connect it between Com and NC pins, you should change false into true.
 322 const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 323 const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 324 const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 325 const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 326 const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 327 const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 // Travel limits after homing
 365 #define X_MAX_POS DELTA_PRINTABLE_RADIUS
 366 #define X_MIN_POS -DELTA_PRINTABLE_RADIUS
 367 #define Y_MAX_POS DELTA_PRINTABLE_RADIUS
 368 #define Y_MIN_POS -DELTA_PRINTABLE_RADIUS
 369 #define Z_MAX_POS MANUAL_Z_HOME_POS
 370 #define Z_MIN_POS 0
//these are the positions on the bed to do the probing,the probe positing should not be beyond the printable radius.
 382 #define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS*0.6)
 383 #define LEFT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
 384 #define RIGHT_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
 385 #define BACK_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
 386 #define FRONT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
//these are the offsets to the probe relative to the extruder tip (Hotend - Probe), these values are very important, especially the Z_PROBE_OFFSET. You can calculate the Z_PROBE_OFFSET values with this procedure:
Manual y Move the print head down slowly, place the probe at the center of the print bed. When you hear the trigger of the endstop, you can get the coordinate on the LCD or on the Repetier host. In my case, it is 【-20.35,11.75,0.3】, you can add it to the following settings.
 389 #define X_PROBE_OFFSET_FROM_EXTRUDER 20.35
 390 #define Y_PROBE_OFFSET_FROM_EXTRUDER -11.75
 391 #define Z_PROBE_OFFSET_FROM_EXTRUDER -0.3
 398 #define Z_RAISE_BEFORE_PROBING 100  //How much the extruder will be raised before traveling to the first probing point.
 399 #define Z_RAISE_BETWEEN_PROBINGS 10  //How much the extruder will be raised when traveling from between next probing points
 // with accurate bed leveling, the bed is sampled in a ACCURATE_BED_LEVELING_POINTSxACCURATE_BED_LEVELING_POINTS grid and least squares solution is calculated
 // Note: this feature occupies 10'206 byte
 431 #define ACCURATE_BED_LEVELING_POINTS 4
 // For delta: Distance between nozzle and print surface after homing.
Till now, you have finished the edit of the firmware, then, you need to upload the modified firmware into your control board. For those not mentioned just leave them as default.
5.Uploard firmware Choose board type.
6.Choose serial port (if you cannot find the serial port, please check the connection of your printer to your computer.)
7.Load in the file you need to burn, Click the “” button to check if it is right and then click the “” button to upload.
8.Upon uploading, the LED indicator corresponding to the TX, RX and L on the GT2560 will blink, if they stop blinking, it means the file has been uploaded successfully.
9.After uploading, you can go on to the next step. If you cannot upload, check the dialog box below to identify the problem and solve it. The common mistakes are the wrong select of type of board or serial port etc.
verify code
* x_max,y_max,z_max is for the endstop:
if the endstop is triggered, the feedback is Triggered;
If the endstop is not triggered, the feedback is Open.
z_min is for the probe:
Trouble shooting:
3.  Get the present coordinates
Send M114 command to get the present coordinates after homing, you can get
 fw(0,0,MANUAL_Z_HOME_POS)
 MANUAL_Z_HOME_POS
This is the distance between nozzle and print surface after homing.
Calibration of auto-leveling
