Acrylic Prusa I3 build instruction(8mm)
Notice:
Unfold and check the package
Tips:
Assemble the rods of a Y axis
Assemble the Y idler
Mount the Y motor
Build the printing platform
Step4. Mount the belt.
Assemble Y - Z axis
Mount the fan
Assemble the 2 Z motors
Assemble the smooth rods
Assemble the X-Axis end
Mount the extruder holder.
Mount the extruder
Mount the X-axis motor
Amount the X-axis belt
Assemble the X-Z axis
Attach he heated bed
Mount the end stops
Step 1.End stop of X-axis
Step2. End stop of Y-axis
Step3. End stop of Z-axis
Mount the LCD panel frame
Mount the PSU
Example 1: Sanguinololu
Step2. Stack the 4 A4988 on Sanguinololu (It is recommended wear static gloves when plugging A4988)
* use the Dupont cable in the package to strech the wire of fan for extruder, you just need to connect the black and red one, leave the yellow one alone.
Note: when connect the other Z-motor, use the 4-pin M-F DuPont cable and pay attention to the directions of the wire. If you connect them reversely, the 2 Z motor will move in different directions.
Example 2: Ramps 1.4
Wiring
2.Connect the fan; both the fan for extruder and the main board are connected like this. As to the fan for extruder, you need another 2-pin DuPont cable to extend.
Take off the adapters and plug the cable into the power port.
When mounting the board on Acrylic plate, the blue part should be near the cooling fan!
3.Connect the heatbed.
4.Connect the extruder
5.Connect the end stops.
6.Connect the power supply.
Mount the board
The blue part on mainboard should be near the cooling fan, otherwise the MOSFET may be burnt out when heating!
Mount the filament spool
