Delta Rostock mini G2 Building Instruction
Preparation
Chapter1 Base Assembly
Motor end assembly
Stepper motor
53
3
Pulley
33
3
Motor holder
A3
3
Motor holder support
A4
6
Square nut
14
6
M3 X 12 Screw
18
12
M3 X 16 Screw
19
6
M3 washer
5
18
base plate
A2
1
Square nut
14
9
M3 X 16 Screw
19
9
M3 washer
5
9
Mount the LCD panel
LCD frame LCD frame
A8
1
LCD support
A9
2
LCD2004
54
1
Square nut
14
4
M3 X 16 Screw
19
4
M3 X 12 Screw
18
4
Spacer
34
4
M3 washer
5
8
Knob
55
1
Mount the fan
Fan(40x40x10)
45
1
M3 X 16 Screw
19
1
M3 x 25 screw
21
2
M3 Square nut
14
1
M3 nut
10
2
M3 washer
5
3
Mount the control board.
Control board GT2560
52
1
Spacer
34
4
M3 X 12 Screw
18
4
M3 washer
5
4
Mount the print bed.
Building platform
36
1
Heatbed
44
1
Hex Counter-sunk-head screw
15
3
Spring 3.5 x 20mm
27
3
Wing nut
13
3
M3 washer
5
6
Here is the finished picture.
Chapter 2 Top Plate Assembly
endstop mount
Top plate
A1
1
Endstop mount
A6
3
Endstop
49
3
Square nut
14
9
M3 washer
5
9
M3 X 16 Screw
19
9
Drive wheel mount
Drive wheel mount
A5
3
Driven wheel holder
32
3
624zz ball bearing
29
6
M3 X16 Screw
19
3
M3 X25 Screw
21
6
M4 X 25 Screw
25
3
M3 nut
10
6
M4 lock nut
12
3
Wing nut
13
3
M3 washer
5
15
Mount the extruder
Extruder
50
1
M5 x 16 screw
26
4
M5 washer
7
4
Find out the locating holes on the top plate; screw up the extruder with 4 M5 x 16 screws and washers.
The screws are bottom - up.
Mount the spool holder
Spool holder Side panel
A10
1
A11
1
M3X16 screw
19
4
Square nut
14
4
Screw up the spool holder panel on the top plate separately with M3X16 screw and M3 nut and washer.
Chapter3 mount the smooth rods
Smooth Rod
1
6
Linear Bearing
30
6
M4 X12 Screw
23
12
M8 Washers
9
12
M4 washer
6
12
Diagonal Rod
1
6
rod-end bearing holder
3
6
Fan(30x30x10)
46
1
Hotend
51
1
Spider washer
P1
1
Hotend bracket
P2
1
Hotend half bracket
P3
1
Fan mount
P5
1
Carriage
P4
3
Automatic leveling
57
1
Zip tie
35
12
Round head screw with pad
16
12
M3 x 8 screw
17
12
M3 x 16 screw
19
6
M3 x20 screw
20
3
M3 x40 screw
22
3
M4 x 16 screw
24
2
3.5*30 spring
28
3
M3 nut
10
7
M4 nut
11
2
M3 washer
5
20
M4 washer
6
2
M6 washer
8
12
Assemble the spider
Step1. Stack the hotend bracket and half bracket together, screw up with 4 M3 x 16 screws and M3 nut.
Insert the hotend into the gap of the bracket.
