Delta Rostock mini G2 Building Instruction
Preparation
Chapter1 Base Assembly
Motor end assembly
Mount the LCD panel
Mount the fan
Mount the control board.
The directions of the spacer are as the arrow showing.
Mount the print bed.
step1. Stack the heatbed and the building platform together.<br.> File:Print bed1.jpq
Step2. Thread the M3X30 screw through the two plates and add washers and spring at this end.<br.> File:Print bed2.jpq
Step3. Lock the other end with a wing nut.<br.> File:Print bed3.jpq
Here is the finished picture.<br.> File:Print bed4.jpq
