Geeetech prusa i3 pro C building instruction
Notice:
Unfold and check the package
Tips:
Assemble the rods of a Y axis
Assemble the Y idler
Mount the Y motor
Build the printing platform
Step4. Mount the belt.
Assemble Y - Z axis
Mount the fan
Assemble the 2 Z motors
Assemble the smooth rods
Assemble the X-Axis end
Mount the extruder holder
Mount the extruder
mount the fan for extruder
Mount the X-axis motor
Amount the X-axis belt
Assemble the X-Z axis
Attach he heated bed
Mount the end stops
Step 1.End stop of X-axis
Step2. End stop of Y-axis
Step3. End stop of Z-axis
Mount the LCD panel frame
Mount the PSU
There is one thing you need to note that the extruder number in this picture is 1 and 2, but in the following steps, I referred them as 0 and 1 correspondingly.
Step1
Step2
Plug the 5 A4988 into the stepper motor driver slot. Mind the directions of A4988.
Step3
Connect wires for motors.
Here you need to use the DuPont wire (NO.64).
Plug the end with one terminal into the Z motor slot. And connect the two wires of Z motor to the two DuPont wires separately.
Note the color of the connection as below:
DuPont wires | Motor wire! |
4) Connect Extruders
As you can see 0 and 1 from the extruder holder [NO.P4], you need to straighten out the two wires and do not mix them up.
Connect extruder 0.
Connect extruder 1.
Step4
Connect heating wires.
2) Connect heating wires for extruder 0.
3) Connect heating wires for extruder 1.
Step5
Connect wires for thermistor.
3) Connect wires for thermistor of extruder 1.
Step6
Connect wires for endstop.
* There is no “+” and “-“for endstop
Step7
Connect wires for Fan.
Note the “+” and “-“for fan
Red: +
Black: -
Step8
Connect wires for LCD panel.
Step9
Connect wires for power input.
Mount the filament spool
