Geeetech prusa i3 pro C building instruction
Notice:
Unfold and check the package
Tips:
Assemble the rods of a Y axis
M10 threaded rod
2
NO.5
Y plate connecting plate
2
NO.A14
M8 spring washer
6
NO.18
M10 washer
8
NO.9
M10 nut
8
NO.12
M8 smooth rod
2
NO.3
LM8UU Linear bearings
4
NO.39
Acrylic plate(front)
2
NO.A9,A10
Acrylic plate(back)
2
NO.A11,A12
M10 washer
4
NO.9
M10 nut
4
NO.12
Assemble the Y idler
624ZZ Ball bearing
2
NO.38
bearing holder
1
NO.66
M3 x20 screw
1
NO.27
M3 wing nut
1
NO.15
M3 x25 screw
1
NO.35
M4 lock nut
1
NO.14
Mount the Y motor
Y motor fix plate
1
NO.A13
Stepper motor
1
NO.75
pulley
1
NO.43
M3 x12 screw
3
NO.25
M3 x16 screw
2
NO.26
M3 square nut
2
NO.16
Build the printing platform
Y platform support
1
NO.A15
Y bearing block
4
NO.A16
Y belt mount
1
NO.67
Zip tie
4
NO.54
M3 x10 screw
2
NO.24
M3 x20 screw
8
NO.27
M3 nut
8
NO.11
Step4. Mount the belt.
Timing belt
1
NO.41
M3 x10 screw
2
NO.24
M3 washer
2
NO.7
Assemble Y - Z axis
X-Z frame
1
NO.A1
Acrylic fender
2
NO.A12
M3 x20 screw
4
NO.27
M3 nut
4
NO.11
Mount the fan
Fan
1
NO.71
M3 x30 screw
4
NO.28
M3 lock nut
4
NO.13
Acrylic left panel
1
NO.A2
Acrylic right panel
1
NO.A3
M3 x16 screw
8
NO.26
M3 square nut
8
NO.16
Z Motor fixed plate
2
NO.A4,A5
Z Motor support plate
4
NO.A6,A7
M3 x16 screw
10
NO.26
M3 square nut
10
NO.16
Assemble the 2 Z motors
Stepper Motor
2
NO.75
M3 x12 screw
8
NO.25
Assemble the smooth rods
370mm smooth rod
2
NO.2
LM8UU linear bearing
2
NO.40
624ZZ Ball bearing
2
NO.38
Bearing holder
1
NO.66
M3 X30 screw
1
NO.28
M4 X25 screw
1
NO.35
M4 locknut
1
NO.14
Assemble the X-Axis end
X-axis left end
1
NO.P1
X-axis right end
1
NO.P2
2
NO.40
M3 X16 screw
2
NO.26
M3 wing nut
2
NO.15
M3 nut
2
NO.11
Brass nut
2
NO.17
M3 x 16 screw
8
NO.26
M3 x50 screw
1
NO.31
M3 nut
1
NO.11
Screw locking ring
2
NO.19
print bracket
1
NO.P3
Zip tie
4
NO.54
2
NO.40
Mount the extruder holder
Extruder bracket
1
NO.P4
M4 x16 screw
2
NO.34
M4 nut
2
NO.11A
Mount the extruder
MK8 dual extruder
1
NO.79
M4 x12 screw
2
NO.34
M4 nut
2
NO.11A
mount the fan for extruder
fan
1
NO.70
M3 x30 screw
2
NO.28
M3 washer
2
NO.7
Mount the X-axis motor
Stepper motor
1
NO.75
Pulley
1
NO.43
M3 x8 screw
3
NO.23
Amount the X-axis belt
Belt
1
NO.42
Zip tie
2
NO.54
Assemble the X-Z axis
L322 threaded rod
2
NO.4
Couplings
2
NO.69
Z-axis top mount
2
NO.A8
M3 x16 screw
4
NO.26
M3 square nut
4
NO.16
Attach he heated bed
MK2A Heat bed
1
NO.71
Borosilicate glass
1
NO.72
Heating wire
2
NO.51
Thermistor
1
Attached on the bed
Thermometry wire
2
NO.50
Wing nut
4
NO.15
Spring
4
NO.37
M3 x35 screw
4
NO.29
clamp
4
NO.53
Mount the end stops
Step 1.End stop of X-axis
End stop
1
NO.44
M2.5 x12 screw
2
NO.21
Step2. End stop of Y-axis
End stop
1
NO.45
M2.5 x16 screw
2
NO.22
M2.5 square nut
2
NO.10
Step3. End stop of Z-axis
End stop
1
NO.46
M3 x16 screw
2
NO.22
M3 nut
2
NO.11
Mount the LCD panel frame
LCD 2004
1
NO.80
LCD frame
1
NO.A21
LCD frame holder
2
NO.A23
Acrylic washer
4
NO.A20
M3 x20 screw
6
NO.27
M3 nut
4
NO.11
Mount the PSU
PSU
1
NO.74
M3 x10 screw
3
NO.24
M3 x16 bolt
2
NO.36
M3 nut
2
NO.11
3D Power cable
1
NO.52
Example 1: Sanguinololu
Example 2: Ramps 1.4
Wiring
3.Connect the heatbed.
4.Connect the extruder
5.Connect the end stops.
6.Connect the power supply.
Mount the board
M3 x20 screw
4
NO.27
M3 x40 screw
2
NO.30
M3 nut
4
NO.11
spacer
4
NO.48
Mount the filament spool
Filament side panel
3
NO.A17,18
M3 x16 screw
4
NO.26
M3 square nut
4
NO.16
PVC tube
2
NO.60,61
