GT2560
Revision as of 03:42, 9 February 2015 by Admin (talk | contribs) (Source)
1.Integrated with the mighty function of the Arduino Mega2560+Ultimaker, The GT2560 can not only take full place the Arduino Mega2560+Ultimaker on respect of both software and hardware, but also features compact size, more convenient connection, and more stable.
3. The power pack: operating voltage is 12V-24V; double power supply design feeds for heatbed and logical part separately. The current is 12A for heatbed and 5A for other parts. The cooling fan can support 12V
                         (front and back images)
Hardware resources:
3 input for12V cooling fan
1 PWM output
Weight: 80 g
Software Resources
Firmware: Marlin
Host software:printrun Repetier-Host
Source
[Arduino ide] Marlin:http://www.geeetech.com/wiki/images/3/39/Marlin-Marlin_v1.zip
printrun: http://www.geeetech.com/wiki/images/e/e1/Printrun-Win-Slic3r-10Mar2014.zip
Repetier-Host: http://www.geeetech.com/wiki/images/3/36/SetupRepetierHost_1_00.zip
Interface specifications
1.DC IN: 12V 12A and 12V 5A
2.HOT_BED: heat bed
5.LCD ENCODER: LCD panel
6.SD Card
7. X_MIN/X_MAX/Y_MIN /Y_MAX /Z_MIN /Z_MAX: 6 end stop input
8. TEMP1: temperature sensor for extruder 1
9. TEMP2: temperature sensor for extruder 2
10. TEMP3: temperature sensor for heatbed
11. X,Y,Z:Stepper motors for X, Y, Z axis
12. EXT1, EXT2(A):Stepper motors for extruder 1 and extruder 2
13. FAN1,FAN2,FAN3:3 12V cooling fans
14. PWM: PWM output for cooling fan
2-2
Turn ON/OFF            Subdivision
MS1    MS2    MS3
OFF    OFF    OFF    full step
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
ON     ON     ON     1/16 step
MS1    MS2    MS3
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
OFF    OFF    ON     1/16 step
ON     OFF    ON     1/32 step
OFF    ON     ON     1/32 step
ON     ON     ON     1/32 step
3 Development Environment setting
3.1 Interface Connecting and Setting
Note: Pay attention to the Plus-n-Minus of the power connector, reverse connection can cause irrevocably damages.
3.2 Software setting
3.3 File Burning Windows users need install driver before uploading. The board: Tools > Board > Arduino Mega 2560 or Mega ADK, as shown below.
firmware, as shown below.
4 Get Started
#define BAUDRATE 250000
#define MOTHERBOARD 7
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_BED 1
 #define EXTRUDE_MINTEMP 170
#define INVERT_X_DIR false
#define INVERT_Y_DIR true
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_POS 205
#define X_MIN_POS 0
#define Y_MAX_POS 205
#define Y_MIN_POS 0
#define Z_MAX_POS 200
#define Z_MIN_POS 0
5 FAQ
At most 2 extruders, GT2560 supports 5 A4988 stepper motor drivers, they are X/Y/Z axis and 3 extruders.
2. What is the Power Requirement of GT2560?
It is 12V 12A for the heatbed and 12V 5A for the logical part.
6 How to get
Visit here now!
