Me Creator
- High Cost-Effective
- Resolution up to .1mm
Technical Specifications
Physical Dimensions
Printing Specifications
Layer Resolution:0.1mm
Filament Type:ABS, PLA
Filament Diameter:1.75mm
Temperature
Max Heated Bed Temp:0-110 ℃
Max Extruder Temp:0-250 ℃
Electrical
Power Requirement:120W
Connectivity:USB
Mechanical
Chassis:Steel Frame
Build Platform:Aluminum
Operation
Placement
Connectivity
Modifications
Install the drivers
Windows 8
Windows Manual Install
How To Connect
[font color="red"]In Mac, you should finish step 5&6 in "Printer>Printer settings".[/font]
Leveling The Print Bed
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
Unblocking Procedures
Types of Blocks
- The Stubborn Filament
- Filament broke mid print
Tweezers
Dental Pick
Filament
Long Skinny Metal Object
The Cold Block
- Identification
- Solution
The Hot Block
- Identification
- Solution
- Solution 1: Break the block
Alternative: Acetone bath
Cleaning the Drive Gear
detailes 0f me creator
heatbed -
Belts of x,y axis -
Belt of z axis -
MK8 extruder -
Print carriage
where to get
