Acrylic Prusa I3 build instruction(8mm)
Revision as of 10:12, 28 January 2015 by Admin (talk | contribs)
Warning:
  2. Building and operating 3D printer involves electricity, so all necessary precautions should be taken and adhered to.
  3. Building a 3d printer requires a certain amount of handling ability and some common sense and working principle of 3D printer.
However, do not worry; with this build instruction in hand, you can finish the assembly easily.
Unfold and check the package
·All the acrylic plate has been etched with part ID.
Tips:
Assemble the rods of a Y axis
M10 threaded rod
2
NO.5
Acrylic Fender
2
NO.A14
M8 spring washer
6
NO.18
M10 washer
8
NO.9
M10 nut
8
NO.12
M10 washer > M8 spring washer >M10 screw > M10 screw > M10 washer > acrylic fender > M10 washer > M8 spring washer > M10 screw > M10 screw > M8 spring washer > :M10 washer
M8 smooth rod
2
NO.3
LM8UU Linear bearings
4
NO.38
Acrylic plate(front)
2
NO.A9,A10
Acrylic plate(back)
2
NO.A11,A12
M10 washer
4
NO.9
M10 nut
4
NO.12
Slide the rods into the acrylic plate, Adjust the length so that the smooth rods fit snugly between the front and back piece.
Each corner gets a washer and a nut. Adjust the inner and outer nuts so that the end of the rod is flush with the outside M10 nut.
Do the same on all four corners.
Tips: the Y-axis must be a rectangle, that is the rods on both side should be parallel, so is the front and back plate. Otherwise it will cause obstruction for the belt later.
Assemble the Y idler
624ZZ Ball bearing(front)
2
NO.37
Y belt holder
1
NO.65
M3 x20 screw
1
NO.27
M3 wing nut
1
NO.15
M3 x25 screw
1
NO.34
M4 lock nut
1
NO.14
Step1. Thread the M3 x 20 screw through the Y idler piece.
Put the M4 x25 screw through the holes with the 624ZZ bearings in between. Lock the other end with a M3 nut.
Step2. Mount the assembled idler onto the front support plates. And screw it with a wing nut.
Mount the Y motor
Y-axis motor block
1
NO.A13
Stepper motor
1
NO.75
pulley
1
NO.42
M3 x10 screw
3
NO.24
M3 x20 screw
2
NO.27
M3 square nut
2
NO.16
Insert the motor block into the slot; you may need to use a little strength to do this. But be careful in case the Acrylic broke down. Then screw the motor on the block plate with M3 x 10 screws.
Build the printing platform
Printing platfrom
1
NO.A15
Acrylic fender
4
NO.A16
Y-axis belt mount
1
NO.66
Zip tie
4
NO.53
M3 x10 screw
2
NO.24
M3 x20 screw
8
NO.27
M3 nut
8
NO.27
Step2. Mount the 4 Acrylic fenders on the platform with M3 x 20 screws and M3 nuts on the same side with the belt-mount.
Step4. Mount the belt.
belt
1
NO.40
M3 x10 screw
2
NO.24
M3 washer
2
NO.66
Drill a hole on one end of the belt(the hole can be as the diameter of the M3 screw, leave enough margin )
Fix it on the belt -mount with a M3 x 10 screw and washer.
Thread the belt through the pulley on the Y motor and the Y idler.
Drill a hole on the other end of the belt and fix it on the belt -mount with a M3 x 10 screw and washer.
Step5. Attach he heated bed.
You can also attach the heat bed later.
Heat bed
1
NO.71
Borosilicate glass
1
NO.72
Heating wire
2
NO.50
Thermistor
1
Attached on the bed
Themometry wire
2
NO.49
Wing nut
4
NO.15
Spring
4
NO.36
M3 x30 screw
4
NO.28
clamp
4
NO.52
*The circled part needs soldering.
Assemble Y - Z axis
The main frame is held upright after the acrylic fender washers on the Y axis threaded rods. The front of the plate should be sticking out a lot further than the back. Screw up the frame to the threaded rod of Y-axis.
X-Z frame
1
NO.A1
Acrylic fender
2
NO.A12
M3 x20 screw
4
NO.27
M3 nut
4
NO.11
Mount the fan
Fan
1
NO.70
M3 x30 screw
4
NO.28
M3 lock nut
4
NO.13
Fix the fan on the right side of the frame with 4 M3 x 30 screw and locknut. Mind the direction of the wires.
Acrylic left panel
1
NO.A2
Acrylic right panel
1
NO.A3
M3 x20 screw
8
NO.27
M3 square nut
8
NO.16
Screw up the X-Z frame and the side panel then connect the rear part of the Y axis and the side panel together. You may need to adjust the distance of the X-Z frame to the rear plate.
Z Motor fixed plate
2
NO.A4,A5
Z Motor support plate
4
NO.A6,A7
M3 x20 screw
8
NO.27
M3 square nut
8
NO.16
Screw up the acrylic plates with M3 x 20 screws and M3 square nuts.
Assemble the 2 Z motors
Stepper Motor
2
NO.75
M3 x16 screw
8
NO.26
Step2. Screw up the motors with M3 x 16 screws.
Assemble the X-Axis Idler
624ZZ Ball bearing
2
NO.37
X belt holder
1
NO.65
M3 x30 screw
1
NO.28
M4 x25 screw
1
NO.34
M4 lock nut
1
NO.14
M3 Wing nut
1
NO.15
X-axis end
2
NO.P2
LM8UU linear bearing
2
NO.39
Put the screw through the printed Y idler piece, with the 624ZZ bearings in between. Lock the other end of a M3 nut.
Mount the assembled idler into the X-axis end. Lock it up with a wing nut. Here, you can insert the linear bearing into the end.
Insert a linear bearing into the other end of X-axis.
370mm smooth rod
2
NO.2
2
NO.39
Brass nut
2
NO.17
M3 x16 screw
8
NO.26
Screw locking fender
2
NO.19
Thread the two rods into the two X-axis ends and then mount the brass nut under both ends.
Thread the zip-tie through the extruder bracket
belt bracket
1
NO.P3
Zip tie
4
NO.53
Step1. Mount the X-axis belt bracket on the smooth rods. As you can see from the picture, the two linear bearings should be placed into the two slot of the bracket. Tie them up with zip ties.
Mount the extruder support
Extruder bracket
1
NO.P4
M4 x16 screw
2
NO.33
M4 lock nut
2
NO.14
Mount the extruder
MK8 extruder
1
NO.79
MK8 assemble board
1
NO.64
M4 x8 screw
2
NO.31
M4 x12 screw
2
NO.32
This is the fully assembled MK8 extruder in the package.
Mount the aluminum plate under the extruder. Use 2 M4 x 8 screws to fix.
Then mount the assembled extruder on the extruder bracket. Use 2 M4 x 16 screws to fix.
Mount the X-axis motor
Stepper motor
1
NO.75
Pulley
1
NO.42
M3 x8 screw
3
NO.23
Amount the X-axis belt
Belt
1
NO.41
Zip tie
2
NO.53
Thread the belt through the motor end. The belt is attached on the pulley.
Another end of the belt should be threaded through the belt holder on the right end of the X-axis.
Assemble the X-Z axis
L300 threaded rod
2
NO.4
Couplings
2
NO.69
*Mind the opening of the couplings, the larger opening should be put into the shaft of the motor.
Z-axis top mount
2
NO.A8
M3 x20 screw
4
NO.27
M3 square nut
4
NO.16
Mount the end stops
Step 1.End stop of X-axis
End stop
1
NO.43
M2.5 x12 screw
2
NO.21
Step2. End stop of Y-axis
End stop
1
NO.44
M2.5 x16 screw
2
NO.22
M2.5 Hex nut
2
NO.10
Step3. End stop of Z-axis
End stop
1
NO.45
M2.5 x16 screw
2
NO.22
Mount the LCD panel frame
LCD 2004
1
no
LCD frame
1
no
LCD frame holder
2
no
Acrylic washer
4
no
M3 x20 screw
4
NO.27
M3 nut
4
NO.11
Mount the filament spool
Filament side panel
3
NO.A17,18
M3 x20 screw
4
NO.27
M3 square nut
4
NO.16
PVC tube
2
NO.59,60
Mount the PSU
PSU
1
NO.74
M4 x12 screw
4
NO.32
M3 x20 screw
2
NO.27
M3 nut
2
NO.11
Power cablet
1
NO.61
Mount the PSU on the right side panel with 4 M4 x 12 screws.
Step1, plug the jumper caps on the following pins of the board. (In the yellow circle) These caps are very tiny; do not throw them away inadvertently.
Step2. Stack the 5 A4988 on Sanguinololu
