3.2TFT LCD
introduction
HY-TFT320 is a 3.2 inch TFT LCD Screen module, 320*240 (resolution), 65K color, 34pins interface , not just a LCD breakout, but include the Touch screen, SD card. So it’s a powerful extension module for your project.
This Screen includes a controller SSD1289, it’s 16bit data interface, easy to drive by many MCU like STM32 ,AVR and 8051.HY-TFT320 is designed with a touch controller in it . The touch IC is XPT2046 , and touch interface is included in the 34 pins breakout. Another useful extension in this module is the SD Card socket . It use the SPI mode to operate the SD card, the SPI interface include in the 40pins breakout.
Application Ideas
- Digital Photo Frame (DPF)
- Video terminals
- Instrumentation
- GPS
- Game consoles
Specification:
- 3.2" Color TFT LCD
- 320 x 240 Resolution
- 65,536 Colors (16 Bit)
- Powerful 16 Bit Microcontroller(SSD1289)
- Built-in video RAM buffer
- Integrated SD card
- 5V Operating Voltage
- LED Backlight
pin difinition
example connections with arduino board:
Display:
The UTFT library is required to be installed to get this screen model display. This library is especially designed for 3.2” TFT LCD screen using 16 bit mode. The library require the following connections.
- Connect HY-TFT320 to Arduino Mega2560
BL CTR(pin23) -> 3.3V VCC -> 3.3V RD(pin4) -> 3.3V GND -> GND DB1~DB8 -> pin D37~D30 DB10~DB17 -> pin D22~D29 RS(pin2) -> D38 WR(pin3) -> D39 LCD_CS(pin1) -> D40 RSET(pin5)-> D41
- Connect HY-TFT320 to Arduino UNO
BL CTR(pin23)-> 3.3V VCC -> 3.3V RD(pin4) -> 3.3V GND -> GND DB1~DB6 -> D8~D13 DB7->A0 DB8->A1 DB10~DB17 -> D0~D7 RSET(pin5)->A2 LCD_CS(pin1)->A3 WR(pin3)->A4 RS(pin2)->A5
Touch Screen:
The LCD has a 3.2" 4-wire resistive touch screen lying over it. The Touch libraryneeds to be installed to get it works. This library is designed for 2.4’’ TFT, 3.2” TFT LCD screen module.
DCLK(pin34)-> D6 T_CS(pin33) -> D5 MOSI(pin30) -> D4 MISO(pin29) -> D3 T_PEN(pin31) -> D2
SD Card:
SCK(pin34) -> D52 SD_CS(pin22) -> D53 MISO(pin29) -> D50 MOSI(pin30)-> D51
How to buy it
Click here to buy 3.2“TFT LCD
