Me Creator
Revision as of 03:31, 4 October 2014 by Admin (talk | contribs) (Introduction)
me creator
  • High Cost-Effective
  • Resolution up to .1mm
Technical Specifications
Physical Dimensions
Printing Specifications
Layer Resolution:0.1mm
Filament Type:ABS, PLA
Filament Diameter:1.75mm
Temperature Max Heated Bed Temp:0-110 ℃
Max Extruder Temp:0-250 ℃
Electrical AC Input:110V—240V, 3A, 50-60HZ
Power Requirement:120W
Connectivity:USB
Mechanical Chassis:Steel Frame
Build Platform:Aluminum
Operation
Placement
Connectivity
Make sure the heating plate and extruder are not heated when starting software. Power
We recommend plugging your Me Creator printer into a surge protector with a circuit breaker. Never attempt to open or fix your power supply. If you believe your power supply is not working properly, contact us asap.
Modifications
Warnings
Install the drivers
Windows
Windows 8
Windows Manual Install
1) Download and install: Repetier Host Installer
Click on the Manual Controls Tab and click in a direction X or Y to test your connection. If you are having difficulty connecting, please review the following supportive documentation: Installing Drivers and How to connect Please note that if you had difficulty connecting, there might have been an issue with the installation process. Ensure that the following have been installed:
Download and install the Serial Driver. Download and install Microsoft .netFrameWork 3.5
How To Connect
4. Hit connect in the upper left-hand corner. You should see the details of the connection in the console window in the bottom section of the screen. Show image here
Leveling The Print Bed
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
Unblocking Procedures
Types of Blocks
The Stubborn Filament
Sometimes filament gets stuck past the extruder drive gear and can be very difficult to remove. This can happen for a variety of reasons:
Drive gear chewed through filament and became detached
Filament ran out while unattended
Filament broke mid print
Extruded the starter filament too far
Tweezers
Dental Pick
Filament
Long Skinny Metal Object
The Cold Block
  • Identification
  • Solution
The Hot Block
  • Identification
  • Solution
Solution 1: Break the block
Solution 2: Remove Hot-End and Clean
Alternative: Acetone bath
Cleaning the Drive Gear
where to get
Get you own Me Creator here and have fan with it.
