Printrboard
Revision as of 02:36, 9 September 2014 by Admin (talk | contribs) (Interface Layout)
Printrboard, a development board, originally based on sanguinololu, is one of the lasted versions of control board for 3D printer. Compared with sanguinololu, what makes Printrboard special is the on-chip USB, removing the need for the FTDI UART (USB-to-serial) IC. On-chip USB means dramatically faster firmware upload times and communication. What’s more, the Printrboard is equipped with a micro SD slot, which means you can paste the print file to the SD card to implement off-line printing. Printrboard is highly integrated, all our Printrboard has been tested rigorously and preassembled before shipping, including the four integrated Allegro A4982 Stepper Drivers (no Pololus needed), which is on the one hand a good thing for a lay man of electronics, but on another hand, it will be difficult for them to repair by themselves if there is some damage. On the whole, the Printrboard is of high capacity-price ratio and friendly to use.
features
1. 4 Non-replacement integrated Allegro A4982 Stepper Drivers.
2. 2 channel high current (30A) device interface for heaters
3. Controllable fan 4. Four endstop connectors supplied 5V. Includes X, Y, Z, and fourth endstop called E-Stop to be used as an emergency stop, or extruder stop (to be added in firmware).
5. 2 thermistor connectivity
6. Power supply (12-20V 120W minimum)
7. Integrated USB interface and on-board SD card slot
8. Expansion headers supporting I2C, SPI, UART, and ADC pins.
9. Support one extruder only
10. Highly integrated and high capacity-price ratio.
Overview and Hardware
size:100mm x 60mm
weight:73g
compiling environment:Arduino IDE firmware:Marlin upper-computer software:Printrun/Repetier-Host
source
Printrun:[1]
Repetier-Host:[2]
Arduino IDE:[3]
Arduino IDE:[4]
Marlin:[5]
Interface
Interface specifications
1. 2 channel ADC interface for thermometry: one for Extruder and another for Heatbed.
2. 3 channel PWM: one for extruder control, one for heatbed and one for fan.
3. 4 channel endstop: for x/y/z/e separately to connect to mechanical or optic endstop or hall sensor.
4. With TF card slot which supports 8G <= FAT16 and FAT32.
Jumper Instruction
NOTE: do remember to put on the jumper cap. Or it will affect the uploading of firmware and the connection with PC.
File Burning
Arduino IDE 1.Windows users need install driver before uploading. The board: Tools > Board > [CDC]teensylu/printrboard ,as shown below.
2.Configuring serial interface: Tools > Serial Port > the corresponding COM Port of Printrboard of is usually the last one. As shown below:
3.Click the to check if it is right and then click to upload firmware, as shown below.
4.Upon uploading, IDE will display the rate of progress; when done uploading appears, the uploading process succeeded.
Software Setting
Arduino IDE Installation 1.Windows will prompt that a new USB device, named DFU was found when connecting USB with Printrboard to the PC. Then, windows will open the dialog box “found new hardware wizard”, check “no, not this time”, then click “next” to continue.
2.Check “install from a list or specific location (advanced)”, then click “next”.
3.Specify “USB32” in Atmel\AVR Jungo USB installation directory to install driver.
4.If everything goes well, windows will install the corresponding driver.The graph below shows installation completed.
Now, you can find the corresponding Printrboard device in device manager of windows.
1.Click configuration > printer setting
2.Set the communication port (the COM port for printrboard) and the Baud rate. Then click ok
3.Click “connect”> upload. Choose the GCODE file you want to print.
Get Started
Printrboard is the CPU of a 3D printer, manipulating the whole process of printing. Printrboard can’t be put in use directly without uploading firmware. 1. Firmware uploading- marlin.
  #define BAUDRATE 250000
  #define MOTHERBOARD 81
This parameter is set for board type. 3D Printer has many types of main board, and the settings of IOs are different, therefore, the parameter has to correspond to the type of your board, or it can’t operate normally. The parameter of Printrboard should be 81(single- nozzle). For other board, you can refer to the annotation on the board.
  #define TEMP_SENSOR_0 3
  #define TEMP_SENSOR_BED 3
  #define EXTRUDE_MINTEMP 170
  #define INVERT_X_DIR false
  #define INVERT_Y_DIR true
  #define X_HOME_DIR -1
  #define Y_HOME_DIR -1
  #define Z_HOME_DIR -1
  #define X_MAX_POS 205
  #define X_MIN_POS 0
  #define Y_MAX_POS 205
  #define Y_MIN_POS 0
  #define Z_MAX_POS 200
  #define Z_MIN_POS 0
Extensible Applications
Exp:IIC、RS232、GPIO,JTAG
FAQS
Click here to reinstall the driver(http://pjrc.com/teensy/serial_install.exe)
3.What type of printer can Printrboard be applied to?
Solidoodle,printrbot,and most type of reprap(with a stepper motor driver for Z axis and single extruder)
4.How come the stepper drivers of X/Y/Z axis cannot run in normal direction?
①The endstops didn’t connect or it is a matter of poor connection.
②The IC of stepper driver broke down
where to get
click here http://www.geeetech.com/new-version-reprap-printerboard-reprap-electronics-sets-p-653.html, you can get the printrboard.
