Ramps1.4
Revision as of 09:54, 30 July 2014 by Admin (talk | contribs) (Interface)
Ramps is short for reprap Arduino mega pololu shield, it is mainly designed for the purpose of using pololu stepper driven board (similar to 4988 driven board). Ramps can only work when connected to its mother board Mega 2560 and 4988/DRV8825. Owning to its stability in operation and great compatibility with most 3Dprinter (all reprap-model such as pursa i2 and i3). The combination of Ramps1.4+MEGA2560+A4988/DRV8825 is becoming a mainstream of DIY 3D printer control board.
1. Standard interfaces (as that of extruder)
2. Reserved GCI like I2C and RS232
3 MOSFET 3 MOSFET are applied to the heater/ fan and thermistor circuit.
4. Adding another 5A to protect the component parts.
5. An 11A fuse is added to the hotbed
6. Support 5 stepper drive board
7. The adoption of Pin Header as pololu makes it more convenient to repair or change.
8. I2C and SPI are reserved for expanding
9. All the MOSFET can be controlled by PWM
10. Use the interface of servo motor to adjust the level of printing platform automatically.
11. Adding a SD module for SD ramps module.
12. LED can indicate the status of the heater (the open and close of MOS).
13. 2 stepper motor for Z axis in parallel.
Overview and Hardware
Weight: 68g Size: 102mm*60mm
Firmware: Marlin
PC software: Printrun, Repetier-Host
Source
Printrun:[1]
Repetier-Host:[2]
Arduino IDE:[3]
Arduino IDE:[4]
Marlin:[5]
Interface
Interface specifications
2 power interfaces 12v 11a/12v 5a 6 motors (one for X axis, one for Y axis, 2 for Z axis, 2 for extruder 2 interfaces for LCD&SD 6 interfaces for end stop(X/Y/Z min, X/Y/Z max) 3 interfaces for PWM (one for hotbed, one for fan and one for extruder) 3 interfaces for thermistor
Jumper Instruction
  jumper       Yes/No     stepsize
   ms1     ms2      ms3
   no      no       no     fullstep
   yes     no       no     halfstep
   no      yes      no     1/4step
   yes     yes      no     1/8step
   yes     yes      yes    1/16step
  jumper   Yes/No       step size
   ms1     ms2      ms3
   no      no       no    full step
   yes     no       no    half step
   no      yes      no    1/4 step
   yes     yes      no    1/4 step
   no      no      yes    1/16 step
  yes      no      yes    1/32 step
  no      yes      yes    1/32step
  yes     yes      yes    1/32step
Precautions: Like other electronics, the inverse connection of power supply can cause irreparable damage to the board (4988 included). You are advised to connect all the components before testing.
File Burning
As Ramps1.4 is just the shield board of Mega2560, the firmware must be burned into Mega2560.
Software Setting
1.Before uploading, driver should be installed for windows. Then choose the type of board: Tools > Board > Arduino Mega 2560 or Mega ADK. (Picture below)
2.Select the serial port: Tools > Serial Port, the serial port for mega is usually the last one.
3.Clickto check if there is any mistake. If not, clickto upload.
4.During the process of uploading, the 3 LEDs corresponding to TX, RX and L on mega board will blink, if the blink stops, the uploading is done.
After the uploading, you can go on with the next step. If the uploading is unsuccessful, read the error report on IDE, figure out the problem, and then try again. some frequent errors are: a wrong select of board type and serial port.
1. Click configuration> printer setting
2. Set the communication port (the COM port for mega) and the Baud rate. Then click ok
3. Click “connect”> upload. Choose the GCODE file you are printing.
Get Started
Mega 2560 is the CPU of a 3d printer, manipulating the whole process of printing. Mega 2560 can’t be put in use directly without uploading firmware.
  #define BAUDRATE 250000
  #define MOTHERBOARD 33
This parameter is set for board type. 3D Printer has many types of main board, and the setting of IOs is different, therefore, the parameter has to correspond to the type of your board, or it can’t operate normally. The parameter of mega should be 33(single- nozzle) or 34 (dual-nozzle). For other board, you can refer to the annotation on the board.
  #define TEMP_SENSOR_0 3
  #define TEMP_SENSOR_BED 3
  #define EXTRUDE_MINTEMP 170
  #define INVERT_X_DIR false
  #define INVERT_Y_DIR true
  #define X_HOME_DIR -1
  #define Y_HOME_DIR -1
  #define Z_HOME_DIR -1
  #define X_MAX_POS 205
  #define X_MIN_POS 0
  #define Y_MAX_POS 205
  #define Y_MIN_POS 0
  #define Z_MAX_POS 200
  #define Z_MIN_POS 0
Extensible Applications
Upload through Bluetooth
The COM should be set as (9600, N, 8, 1) The command for Bluetooth module:
  AT OK
  AT+BAUD8 OK115200BAUD (set baud rate for RAMPS/Arduino Mega)
  AT+NAMEPRUSAI3 OKsetname (optional set name, default: linvor)
  AT+PIN0000 OKsetPIN (optional set pin, default: 1234)
FAQS
1.How many extruders can ramps support?
Ramps 1.4 support 5 A4988 driving boards, which are for X/Y/Z/axis and 2 extruders respectively, so the ramps can support at most 2 extruders.
2. What should I note when provide power for ramps?
The recommended power supply for Ramps is 12V, especially for Mega2560. If supplied over 12v, Mega will over heat, resulting in instability of operation, the serial port communication is was at times strong and at other times weak. Do make sure the power is 12v, if you don’t have switching power supply of 12v, please take down the diode D1 on Ramps if you use a greater power supply. The current is decided by the use of hotbed. If you use a hotbed, an idea power supply is 12v 17A, 200W. If not, 5A is enough.
3. Can fan be added to Ramps?
Yes. If you use only one extruder, you can connect the fan to the 2 pins in the middle of the 6 blue output pins. If you use two extruders, the fan cannot be connected to ramps directly; you should connect it to a power source that is controlled manually. Or you can build an external circuit, the pins of which should be set in the firmware,
4. What is the difference between ramps and ultimaker?
In the respect of function, they are totally alike. But there are some difference, one lies in the configuration of I/O pins. Another lies in the way of reading temperature. Ultimaker uses thermocouple and temperature control board (AD597), ramps uses NTC thermistor 100K. If you want to use thermocouple and temperature control board for ramps, you should take down the pull-up resistor one the thermistor of hot end.
5. Can Ramps replace ultimaker to make an ultimaker printer?
Yes, it can, but you need to pay attention to the points we’ve mentioned in chapter Ⅴ .The ultimaker printer is one kind of reprap, as well as standard three- axis rectangular coordinates
6. The temperature displayed is not normal.
A. you may select the wrong thermistor in marlin, we often choose 1.
B. The thermistor is Brocken or there is short-circuit occurred in the 2 pins of the thermistor.
C. The electrolytic capacitor on ramps is broken.
7. The motor jitters.
A. It is a matter of poor connection,
B. A4988 has broke down,
C, the VREF is not right.
8. The scope of motor is too small.
You may forget putting the jumper cap, or the parameter you set is wrong.
9. The program uploading is not successful.
The USB cable doesn’t work; the version of Arduino IDE you use is not compatible; the select of COM is wrong.
10. The hotbed and extruder can’t heat.
A. The MOSFET is broken.
B. The thermistor is not connected.
11 the motor of extruder doesn’t work.
The thermistor is not connected; the temperature is not enough; A4988 broke down; ramps 1.4 broke down.
