Metal J-head short-distance
This product adopts high-quality aluminum alloy heat radiator and brass nozzle, with stainless steel pipe as feeding pipe, which ensures good heat insulation effect and prevents blockage. Besides, its surface is covered with anodic oxide coating, which can resist oxidation corrosion and increase nozzle hardness, thus ensuring better heat insulation, stronger corrosion resistance as well as finer and more stable printing.
Feature
Configurable cooling fan, cooling effect.
Product Introduction
Printing resolution | 0.1mm |
Molding form | FDM |
Material | Metal |
Nozzle diameter | 0.3, 0.35, 0.4 , 0.5 optional |
Movement speed | 50cc |
Outline dimensions | 70*25*25mm L/H/W) |
Weight | 68g |
Cartridge heater | 12V 30W |
