Arduino YUN
Revision as of 05:38, 23 May 2014 by Admin (talk | contribs) (Summary)
AVR Arduino microcontroller
  • Microcontroller ATmega32u4
  • Operating Voltage 5V
  • Input Voltage 5V
  • Digital I/O Pins 20
  • PWM Channels 7
  • Analog Input Channels 12
  • SRAM 2.5 KB
  • EEPROM 1 KB
  • Clock Speed 16 MHz
Linux microprocessor
  • Processor Atheros AR9331
  • Architecture MIPS @400MHz
  • Operating Voltage 3.3V
  • WiFi IEEE 802.11b/g/n
  • USB Type-A 2.0 Host/Device
  • Card Reader Micro-SD only
  • RAM 64 MB DDR2
  • Flash Memory 16 MB
PoE compatible 802.3af card support (see the note below)
