Reprap Ramps1.4 RRD Fan Extender
Revision as of 06:34, 27 June 2013 by Admin (talk | contribs)
  • max 20V
  • 2 (PWM controllable) channels (D6/D11)
  • max 0.5A per channel (enough for a really big fan)
  • flexible output voltage (you can connect the RRD-FAN-EXTENDER to 12V,5V,... in order to support the output voltage you need)
  • each channel has a fly back diode
  • easy setup (plug and play)
  • already supported by Marlin firmware (choose "#define MOTHERBOARD 34")
  • easy to adapapt to other firmware (e.g. Sprinter: just change "#define FAN_PIN 6" in "pins.h")
Firmware, hardware and settings required:
Firmware:
Hardware required:
- Ramps 1.4
- Mega2560 board
Configuration:
as shown in the product description
